Author Topic: Cam Seal R&R..."No Special Tools" Required  (Read 2493 times)
May 28, 2014, 02:08:14 pm
ftm1776
  • 149
« on: May 28, 2014, 02:08:14 pm »
Bentley gives a procedure to R&R the camshaft seal without "special" tools which requires loosening of the cam bearing caps.
Would this make it possible to easily just slip the old off and slip a new one on?
Are there any special concerns about loosening the caps?
« Last Edit: May 28, 2014, 02:12:09 pm by ftm1776 »
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1May 28, 2014, 02:28:03 pm
Re:
« Reply #1 on: May 28, 2014, 02:28:03 pm »
It is really pretty simple if you undo the cap. The seal is a pretty simple device really.
Reply #2May 28, 2014, 04:08:21 pm
wolf_walker
  • 1205
Re: Cam Seal R&R..."No Special Tools" Required
« Reply #2 on: May 28, 2014, 04:08:21 pm »
Not that I ever noticed, remove cap, replace seal, replace cap.  Beware inaccurate torque wrench, I snapped a stud once.
I just tighten that one by hand now.
Mentat Text Two
Reply #3May 28, 2014, 05:02:30 pm
« Reply #3 on: May 28, 2014, 05:02:30 pm »
Other than the "special" tools needed to time the engine right?  ;)
Reply #4May 29, 2014, 05:33:58 pm
ftm1776
  • 149
« Reply #4 on: May 29, 2014, 05:33:58 pm »
Yeah, that's in a different section in Bentley.
I've got the timing tools...............
Used them once to just check the timing......0.90 mm, on the money !!
293,000 miles
Reply #5May 29, 2014, 07:54:49 pm
8v-of-fury!
« Reply #5 on: May 29, 2014, 07:54:49 pm »
Well then you are set to replace that cam seal. ;)
I didn't use anything special when I  replaced mine.
Reply #6June 01, 2014, 04:01:04 pm
air-cooled or diesel
« Reply #6 on: June 01, 2014, 04:01:04 pm »
you just have to loosen and wiggle off the 1 cap. I use either silicone, or permatex (aviation), on outer portion of seal, try not to get sealant on inner portion of seal-towards inside engine, grease seal I find works best, wipe off extra, but a generous amount on lips, permatex on outer portion of cap, just some.
I guess you end up having to loosen timing sheet metal.(5mm allen).
Reply #7June 02, 2014, 11:11:11 am
ftm1776
  • 149
« Reply #7 on: June 02, 2014, 11:11:11 am »
.......grease seal I find works best.......
Can you be more specific, please?? Grease seal??
Thanks
293,000 miles
Reply #8June 03, 2014, 07:15:41 am
« Reply #8 on: June 03, 2014, 07:15:41 am »
you need some kind of tube on inner of seal, where They run on shaft, I find grease, or a grease w/ some oil mixed in work, put some lube on shaft too and wipe of extra on inner of seal/shaft.
grease -the seal. or at least lube.
Reply #9June 03, 2014, 06:21:47 pm
ftm1776
  • 149
« Reply #9 on: June 03, 2014, 06:21:47 pm »
Gotcha, Air-cooled !!
I've seen it done on  Youtube.
thanks
293,000 miles
