Author Topic: Compressioon Test......Cold or Hot?????  (Read 3115 times)
May 28, 2014, 09:58:33 am
ftm1776
  • 149
« on: May 28, 2014, 09:58:33 am »
I have never done this test.
Bentley says to do the compression check at "normal operating temperature".
Giles at Performance Diesel does his cold; at least on one of his videos.
Although it may be ok, I'm not sure about sucking cold air across hot valves !
Normal temp, cold, ???? what is the preferred temp for the test. Maybe both could tell more than one or the other??
Comments, tips???
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1May 28, 2014, 01:06:25 pm
92EcoDiesel Jetta
Re: Compressioon Test......Cold or Hot?????
« Reply #1 on: May 28, 2014, 01:06:25 pm »
Do both. Cold and Hot.
Reply #2May 28, 2014, 01:21:24 pm
Mark(The Miser)UK
  • 1557
« Reply #2 on: May 28, 2014, 01:21:24 pm »
Comments, tips???
Cold air across inlet valves happens about 3000 times per minute @ 68mph.
Try getting an injector out fast enough for 'normal' operating temperature!
By the time you have the 4th cylinder tested, go back to #1 again...
Try it overnight cold, and warm as possible.
Mark-The-Miser-UK
Reply #3May 28, 2014, 01:26:04 pm
92EcoDiesel Jetta
« Reply #3 on: May 28, 2014, 01:26:04 pm »
Get 4 compression testers. Pull 4 injectors as fast as possible while engine is hot. Install 4 compression testers........Crank away. ;D
Reply #4May 28, 2014, 01:59:53 pm
ftm1776
  • 149
« Reply #4 on: May 28, 2014, 01:59:53 pm »
I guess that is some fire burning in there !!
800 degrees F, I think, on the diesel EGT.
293,000 miles
Reply #5June 15, 2014, 03:14:51 pm
ftm1776
  • 149
« Reply #5 on: June 15, 2014, 03:14:51 pm »
Regarding the "hot" compression test............
My head temp checks out at, say, 165 degrees F(using an infrared thermometer) when I stop the engine in my driveway. The shop replaced rebuilt injectors using the copper Permatex anti-sieze compound. I can see it oozing a little around the injector base where it meets the head.
What would be a good head temp at which to remove the injectors in order to do the compression test?
Should the injectors be removed one at a time or all at once?
After the hot test, I would do an overnight cool down and test all cylinders cold.
« Last Edit: June 15, 2014, 03:20:21 pm by ftm1776 »
293,000 miles
Reply #6June 16, 2014, 08:06:04 pm
Toby
  • 728
« Reply #6 on: June 16, 2014, 08:06:04 pm »
You guys have too much time on your hands. Do it hot because it will be higher than cold and ALL of the compression specs for diesels are HOT not cold. Having been run recently the cylinder walls will be well lubed and the engine will crank faster which is critical if you are trying to determine if you motor is up to spec.
Realistically it takes about 2 minutes to remove the lines and another minute or two to get the injectors out. Loosen all of the injectors at one time and spin them out by hand. The motor will still be plenty warm.
Also put your battery charger on the car while running the compression test. Otherwise the motor may well turn slower on #4 than #1 with a consequent lower reading. Not quite so important on a 4 banger as a V8, but a good idea anyway.
Since cranking speed is critical do it with all of the injectors installed on the bench not the motor.
