Author Topic: Injector Lines Query  (Read 3819 times)
March 21, 2006, 04:30:03 am
weileramer
  • 8
« on: March 21, 2006, 04:30:03 am »
Does anyone know what the actual physical difference is between turbo and NA 1.6 injector lines?   Can I use NA lines on a turbo system?
Reply #1March 21, 2006, 08:13:53 am
fspGTD
  • 1529
« Reply #1 on: March 21, 2006, 08:13:53 am »
Cylinder 3 and 4 injector hardlines are the same (sharing the same VW part numbers) between NA and TD.
Cylinder 1 and 2 injector hardlines are bent differently, comparing NA versions to the TD injector lines.  The TD lines were re-routed to give more clearance to the LDA device.
Jake Russell
