Author Topic: My Gtech Graph now working  (Read 4282 times)
March 20, 2006, 06:11:22 pm
neverdieidi
  • 12
« on: March 20, 2006, 06:11:22 pm »
This is of my 1.6TD after the gov mod, maxing fuel screw and boost at 22psi. Not what I was looking for, for numbers. Torque is lower then I expected and HP isn't as high as I suspected. Any opinions or sugestions on how to get more or if this is what I'm supposed to be getting.
Reply #1March 20, 2006, 06:18:07 pm
Re: Opinion on Gtech Graph
« Reply #1 on: March 20, 2006, 06:18:07 pm »
Quote from: "neverdieidi"
http://www.speedjunkie.ca/forum/album_pic.php?pic_id=3546
Reply #2March 21, 2006, 04:17:57 am
neverdieidi
  • 12
« Reply #2 on: March 21, 2006, 04:17:57 am »
does the link work for other people, cant seem to just post the pic in the thread.
Reply #3March 21, 2006, 04:22:05 am
turbotor
  • 50
« Reply #3 on: March 21, 2006, 04:22:05 am »
Link dosent work  :cry:
Reply #4March 21, 2006, 04:58:49 am
Justin
  • 455
« Reply #4 on: March 21, 2006, 04:58:49 am »
using the G-Tech Pro at school and comparing it to the dynonumbers it was consitent for a pretty good estimate, it was within a few horse when i tested everything, now that the dyno is working properly i need to try the G-Tech to see how accurate it really was since I did some fueling mods since the last time i used the G-Tech
later
Justin
www.archeryprostaffmi.com
Reply #5March 21, 2006, 01:57:22 pm
neverdieidi
  • 12
« Reply #5 on: March 21, 2006, 01:57:22 pm »
Anyone have ideas on why toque is so low, as in didn't change from stock numbers. Could pump timing be a problem?
Reply #6March 21, 2006, 06:31:08 pm
neverdieidi
  • 12
« Reply #6 on: March 21, 2006, 06:31:08 pm »
Would having a bad exhaust leak at exhaust manifold to head cause the turbo to not boost properly and not make good torque?
Reply #7March 22, 2006, 05:37:17 am
« Reply #7 on: March 22, 2006, 05:37:17 am »
Clutch slipping?
84 Scirocco 8v
00 Camaro L36 M49
Reply #8March 22, 2006, 05:27:18 pm
neverdieidi
  • 12
« Reply #8 on: March 22, 2006, 05:27:18 pm »
no opinions on wether the grapgh looks right for the mods I did?
Reply #9March 22, 2006, 05:44:38 pm
HP
  • 225
« Reply #9 on: March 22, 2006, 05:44:38 pm »
edited bcoz it seemed u didn't need my comment
Reply #10March 22, 2006, 05:55:57 pm
neverdieidi
  • 12
« Reply #10 on: March 22, 2006, 05:55:57 pm »
Im comparing the nubers I got with my gtech on my stock engine to what it is now. Here is my base line.
Reply #11March 22, 2006, 06:09:07 pm
neverdieidi
  • 12
« Reply #11 on: March 22, 2006, 06:09:07 pm »
My engine is out of a 85 coupe, but I dont know if the pump is original. The boost pin diameter is smaller and the taper is shorter then what a #51 pin is out of a newer pump. Maybe this is related. Also I just realized that my wastegate is screwed and not dumping boost so it will just boost to what ever the k24 will give me. Thought it may have been a problem with my controller but removed it and boost is still goin through the roof. So maybe this is contributing.
Reply #12March 22, 2006, 06:14:00 pm
« Reply #12 on: March 22, 2006, 06:14:00 pm »
dang, power all the way to 6
Reply #13March 22, 2006, 06:29:54 pm
DVST8R
  • 535
« Reply #13 on: March 22, 2006, 06:29:54 pm »
I would say its a lack of fuel.
The Brett of the board...
The Dark Side of Beauty.[/i]
