Author Topic: Used Holset HE211W for sale (dynoed 173whp on a 1.6TD)  (Read 8689 times)
October 31, 2013, 04:12:51 am
Alcaid
  • 549
« on: October 31, 2013, 04:12:51 am »
Hi,
the Holset HE211W that dynoed 173whp on a 1.6TD is for sale as my friend has moved on to an even bigger turbo, shaft play like brand new and no damage to the wheels. Asking 500$ + shipping (100$ worldwide). PM or email: [email protected]
Original T25 input gasket and downpipe gasket will be included, Cad drawing for flanges also if needed.
Compressor wheel: 56mm / 40.6mm 4+4 blades (early prototype from Holset, these flow slightly more than the 6+6 blades versions)
Turbine wheel: 46.6mm / 41.3mm 11-blades
Turbine housing 5cm^2
These come with 360° thrust bearing stock, 30psi+ is piece of cake all day long
31+lbs/min of air mass flow, somewhere in the region of 210-220hp @ crank on an IDI, 250-260hp @ crank on a TDI. 310hp @ crank for a petrol but I would recommend an external wastegate at some point to avoid boost creep.
The one to the right:
Dyno plot:
173.5whp, 336.4Nm=248.1ft-lbs (torque peak would be higher if pull was started earlier as one can see it reaches full boost before that since torque curve is already falling)
140+whp already at 3000rpm ;)
'10 VW Passat 1.6TDI Highline
Reply #1November 06, 2013, 12:35:22 am
Alcaid
  • 549
Re: Used Holset HE211W for sale (dynoed 173whp on a 1.6TD)
« Reply #1 on: November 06, 2013, 12:35:22 am »
Sold this one locally but I have arranged a deal with my Holset supplier to ship directly to US/CAN if interested. 600$ shipped for a brand spankin' new one :)
« Last Edit: November 06, 2013, 12:39:02 am by Alcaid »
Reply #2November 08, 2013, 09:02:18 pm
shwak23
  • 417
    • Blackdog Junkyard
Re:
« Reply #2 on: November 08, 2013, 09:02:18 pm »
This makes me so wet....
I assume you will include a downpipe flange free with every purchase?
Sent From Outer Space
Reply #3November 14, 2013, 06:36:29 pm
bugnut
  • 89
« Reply #3 on: November 14, 2013, 06:36:29 pm »
Interested, pm sent
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #4November 15, 2013, 08:06:03 am
Alcaid
  • 549
Re:
« Reply #4 on: November 15, 2013, 08:06:03 am »
No flange, but I can post a CAD drawing of the flange to make it youself or have it water or lazer cut locally
Reply #5February 11, 2014, 07:01:53 am
« Reply #5 on: February 11, 2014, 07:01:53 am »
Here is a post bump to help Alcaid sell this and Gizmoman to find this turbo. I am trying to advance the sale.
Reply #6February 11, 2014, 11:39:35 pm
Alcaid
  • 549
« Reply #6 on: February 11, 2014, 11:39:35 pm »
625$ including PayPal fees ;)
Reply #7February 12, 2014, 08:08:33 am
« Reply #7 on: February 12, 2014, 08:08:33 am »
Do you have a dyno graph that includes the 0-3,000 rpm range?
Reply #8February 12, 2014, 08:48:27 am
Alcaid
  • 549
« Reply #8 on: February 12, 2014, 08:48:27 am »
Unfortunately no, owner was worried for the stock rods even though I tried to convince him a pull from 1500rpm would give more valuable spool up data ;)
Reply #9February 12, 2014, 09:09:14 am
« Reply #9 on: February 12, 2014, 09:09:14 am »
Regardless, it is impressive.
Reply #10February 12, 2014, 09:21:33 am
damac
  • 531
« Reply #10 on: February 12, 2014, 09:21:33 am »
what has to be done to a stock td engine to take advantage of something like this?
1985 turbo diesel jetta
Reply #11February 12, 2014, 12:29:53 pm
Alcaid
  • 549
« Reply #11 on: February 12, 2014, 12:29:53 pm »
No need for anything but a stock engine, but in the 173whp example it was a bone stock 1.6TD bottom end, bone stock 1.9TD/AAZ head, this turbo, a good FMIC setup and a 11mm pump build by Dieselmeken in Sweden, thats about it
Reply #12February 12, 2014, 12:45:17 pm
Jetmugg
  • 530
« Reply #12 on: February 12, 2014, 12:45:17 pm »
This is a very fair price, and I wish I had one of these turbos to compare performance to the Garrett GT2056 currently on my 167 HP 1.5L.
However, I can't afford the cost to find out if it would represent an improvement.
Best of luck with the sale, Alcaid!
Steve.
Reply #13February 12, 2014, 01:30:58 pm
« Reply #13 on: February 12, 2014, 01:30:58 pm »
New rules in the for sale section of commenting on threads. This I consider interest and moving the thread in a consistent manner to sell the product with the questions stated. It is trending to discussion and that is what we are trying to avoid as several members have PM'ed me about in other threads.
In short, you guys are all awesome and we are doing great, keep mindful of these things and keep it up.
Reply #14February 15, 2014, 01:07:19 am
Thezorn
  • 381
« Reply #14 on: February 15, 2014, 01:07:19 am »
"Sold this one locally but I have arranged a deal with my Holset supplier to ship directly to US/CAN if interested. 600$ shipped for a brand spankin' new one"
Is this actually a thing?
Compounded 93 AAZ
