Author Topic: Help with turbo selection!!!!  (Read 13543 times)
October 14, 2013, 01:34:18 pm
Gator79
  • 53
« on: October 14, 2013, 01:34:18 pm »
I have a aaz that I was running a callaway manifold and turbo on, the manifold and turbo happen to break and blow at the same time.
So now I'm left with getting a new manifold and turbo and have no idea on what would be best. Not interested in oem aaz or 1.6td turbo set ups I want to go aftermarket. This will be for a daily driver not looking for high horse power or anything crazy just a good fun dd.
Reply #1October 14, 2013, 10:43:35 pm
Re: Help with turbo selection!!!!
« Reply #1 on: October 14, 2013, 10:43:35 pm »
stop... go look at theman's build thread in this section.. his holeset set up.. uses calloway style manifold.. he found repos for good price.. and holset turbo too...
id try that so down pipe/ic plumbing can sort of match up..
Reply #2October 15, 2013, 04:24:50 am
« Reply #2 on: October 15, 2013, 04:24:50 am »
no that turbo isn't ideal for a daily drive tho
Reply #3October 16, 2013, 05:02:16 pm
CrazyAndy
  • 739
« Reply #3 on: October 16, 2013, 05:02:16 pm »
Not even an OEM VNT?  That would be fun.
Reply #4October 17, 2013, 04:45:20 am
Re:
« Reply #4 on: October 17, 2013, 04:45:20 am »
I will say that the holset I have works well as a daily. If you are not looking for ultimate power then the other one alcaid recommends is the he211w it is supposed to do almost as well as the one I have the he221w. I am cruising with .5 to 3 psi at 55 mph and it boosts well. So the slightly smaller he211w should be perfect for a daily. I think both use t 25 manifolds.
Reply #5October 19, 2013, 12:00:40 pm
Alcaid
  • 549
« Reply #5 on: October 19, 2013, 12:00:40 pm »
Both are T25 yes, even the smallest HE211W should do 200bhp on these IDI engines (dynoed 173whp on a 1.6TD)
'10 VW Passat 1.6TDI Highline
Reply #6October 21, 2013, 01:59:12 pm
« Reply #6 on: October 21, 2013, 01:59:12 pm »
I really like the way my GT2056V performs...
my favorite turbo on a warmed-up 1.6TD is the VNT17 off a stock TDI tho..
oh god, they pull hard, make plenty of boost, and sound amazing with a straight exhaust!
Reply #7October 21, 2013, 02:20:04 pm
Re: Re: Re: Help with turbo selection!!!!
« Reply #7 on: October 21, 2013, 02:20:04 pm »
Vnt 15 were most of the stock TDI. Even what is called was the 17 was a 1549vb.  IIRC
 For what I have ran a big turbo is just fine. The holset I have now is large and spools better than my old k24 did. So I say big turbos always.
Reply #8October 21, 2013, 02:34:21 pm
Re:
« Reply #8 on: October 21, 2013, 02:34:21 pm »
To add to this. After having a couple 270 degree bearings and a couple 360 degree bearings in the turbos I would only recommend the 360. I think the 270 degree bearing is the entire reason some say that the t3 and k24 are slow to spool. Obviously I haven't had a ball bearing turbo but imagine they are better yet. I have heard they are not as long lasting as our regular bearing turbos. Fwiw the rebuilder says every holset comes with a 360 bearing stock. The small Cummins turbo I think would be on the absolute big side of what could work for us.
Reply #9October 22, 2013, 12:05:18 am
Alcaid
  • 549
« Reply #9 on: October 22, 2013, 12:05:18 am »
All Holsets have 360° thrust bearings, IMO running these IDI engines with a 270° thrust bearing turbo is a disaster meant to happen as the thrust forces these turbos sees needs the support and lubrication of the 360° bearing. The OEM Garretts and KKKs brake down in no time when you crank up the boost to a decent level.
Reply #10October 23, 2013, 02:25:28 pm
« Reply #10 on: October 23, 2013, 02:25:28 pm »
GT1749V (vnt15) my bad...
my VNTs always spooled faster than the K24 i ran..
i ran my K24 with a "magic" (unhooked) wastegate...
Reply #11October 24, 2013, 12:28:38 am
Alcaid
  • 549
Re:
« Reply #11 on: October 24, 2013, 12:28:38 am »
Worth mentioning is that the HE221W you are running is not the most common one, as that one has a 7cm turbine housing (your's is 5cm) and slightly bigger wheels so it would be way more laggy on our small displacement engines. The one you have is a newer and improved version that's just recently been released on the market.
Reply #12October 24, 2013, 06:23:43 am
« Reply #12 on: October 24, 2013, 06:23:43 am »
How do you specify the 5cm housing? FWIW I like the turbo, and would never have another turbo without the 360 bearing. That T3 with the 360 was cool too. I am mostly afraid of the V band to silicone coupler on mine. If someone made a 1.75 v band in aluminum or if over there you have some on the industrial engine it was designed for I maybe interested. Over here they are non existent.
Reply #13October 24, 2013, 07:27:08 pm
One_punchmachinegun
  • 261
« Reply #13 on: October 24, 2013, 07:27:08 pm »
What do you think the holset would be like on a Tdi, I'm figuring the K24 will go at some point. Would you recommend the one your running for a Tdi, also interested in the HE211W. When I search the turbo, almost all the sites look like the turbos are manufactured in China. Also from what I have seen in searching is that they come on a Cummins engine?
“If anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #14October 24, 2013, 08:03:47 pm
« Reply #14 on: October 24, 2013, 08:03:47 pm »
I bet the 211 would be perfect on a TDI
