For Sale/Looking For
Parts for Sale/Wanted
Needed k14 wastegate
Topic: Needed k14 wastegate (Read 3924 times)
October 01, 2013, 01:36:09 pm
bbob203
October 01, 2013, 01:36:09 pm »
Someone ought to have a dead k14 laying around they could sell me the wastegate off of mine is stuck shut.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
October 01, 2013, 07:59:14 pm
sdubfid
Re: Needed k14 wastegate
October 01, 2013, 07:59:14 pm »
you can service your stock one, I had the same issue
October 02, 2013, 12:14:06 am
phaetonv10
Re:
October 02, 2013, 12:14:06 am »
Could you kindly explain how can I service the old one. Mine is stuck open.
THE LEMON
1.6 GTD, FMIC, ARP Studs, Brembo brakes, Power Clutch, ibiza tdi twin fan setup, Racing Seats, 40 mm all aluminium radiator, audiophile music.
October 02, 2013, 04:48:32 am
bbob203
October 02, 2013, 04:48:32 am »
Quote from: sdubfid on October 01, 2013, 07:59:14 pm
problem is it was very rusty and I had it rebuilt abd the interface where it bolts to turbo is pretty eroded that it may not seal good.
03 Jetta wagon TDi
October 02, 2013, 04:55:10 am
Re: Re: Needed k14 wastegate
October 02, 2013, 04:55:10 am »
It will seal fine. It drops down in and has a sealing washer. Plus carbon soot will plug it off if it wouldn't seal. The issue will be getting it free and working. Most have had success but some don't.
Sent from my DROID RAZR using Tapatalk 2
Round 2
October 02, 2013, 09:41:58 pm
sdubfid
October 02, 2013, 09:41:58 pm »
I sliced slots around the canister with a zip disc, pried the canister off, reamed out the bore slightly and polished the wastegate stem. Then re-crimped the canister back on. Works good as new. It is not meant to be serviced but can be done for free.
