Author Topic: Anyone have a CLEAN catch can setup?  (Read 6344 times)
August 29, 2013, 07:04:51 am
shwak23
  • 417
    1990 VW Golf TD. Engine Code CY
    • Blackdog Junkyard
« on: August 29, 2013, 07:04:51 am »
Well do you? Do the hoses need to remain the same size as stock or could one use something like the bfi valve cover and run some braided stainless with fittings?
Prefer to see setups that drain back into the block. But anything is fine.
No Mason jars ;)
Sent from Outer Space!
Reply #1August 29, 2013, 02:38:52 pm
Re: Anyone have a CLEAN catch can setup?
« Reply #1 on: August 29, 2013, 02:38:52 pm »
My mason jar and vinyl hose stay pretty clean ;D
on the outside at least
Reply #2August 29, 2013, 03:41:27 pm
« Reply #2 on: August 29, 2013, 03:41:27 pm »
There is a surprising amount of volume on some of these engines going through that tube.. So tale that in to affect.
If you under size it you will cause pressure in the crank case.. and oil will start puking from places it should not.
Reply #3August 29, 2013, 07:15:49 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Re: Anyone have a CLEAN catch can setup?
« Reply #3 on: August 29, 2013, 07:15:49 pm »
I seem to recall you saying this in another thread which is why I asked to confirm.
 I am not talking about using 3/8" line though. Just something a bit smaller. What's on there now? Like 1"? Would half inch line be ok? I seem to recall someone on this site having a setup with the catch can attached to the head somewhere and then leading to the block.
Reply #4August 30, 2013, 07:57:35 am
damac
  • 531
« Reply #4 on: August 30, 2013, 07:57:35 am »
I am no techie.
I have put a fitting on each engine I got between valve cover tube and the block fitting.  But since that fitting was a smaller barb over the big one on valve cover, I have been just using that size as far as the hose/fitting going down to block.
Is that ok or would the block hose need to be the same size?
Your post just made me wonder :)
I made an inline catch can out of pvc cannister, plugs with threads for fittings and stainless steel balls inside and it definately did something on an engine I was using that had lots of blowby.  Let it build up and go down into block.
1985 turbo diesel jetta
Reply #5September 05, 2013, 10:16:30 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #5 on: September 05, 2013, 10:16:30 pm »
Does no one here have a nice setup? I think I have seen at least one. One of the more baller builds on this site. I don't recall who...
Reply #6September 05, 2013, 10:22:46 pm
  • 4553
« Reply #6 on: September 05, 2013, 10:22:46 pm »
I recently removed my blowby setup.  I picked up on a Volvo unit and had it plumbed into the VC and then down to a secondary catch can so I could easily empty any oil I was pulling out of the system.  I only ran it for a while then the rings just gave up on the #3 cylinder so I pulled the head and did the proper repair.
So I have that catcher if you want to offer on it.  Do me a PM and maybe we can set up something.  I surely don't need it anymore.
DAS
Reply #7September 06, 2013, 04:44:34 am
Jetmugg
  • 530
« Reply #7 on: September 06, 2013, 04:44:34 am »
I'm running A/N fittings, braided line, and a Moroso puke tank mounted in front of the core support.  It does not drain back to the block, however.
Reply #8September 06, 2013, 10:44:57 am
  • 4553
« Reply #8 on: September 06, 2013, 10:44:57 am »
I didn't drain mine back because I wanted to see how much oil it was going to pull out of the vapors going into the intake.  I didn't keep it on long enough to find out.
Reply #9September 06, 2013, 12:50:02 pm
bbob203
  • 1789
« Reply #9 on: September 06, 2013, 12:50:02 pm »
Im uneducated why a catch can?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #10September 06, 2013, 02:36:22 pm
« Reply #10 on: September 06, 2013, 02:36:22 pm »
DAS
The one I sold you was from a Mercedes-Benz 240D, late 70s or early 80s.
Reply #11September 06, 2013, 02:38:31 pm
92EcoDiesel Jetta
« Reply #11 on: September 06, 2013, 02:38:31 pm »
Same here. Why?
Reply #12September 06, 2013, 02:54:20 pm
stewardc
« Reply #12 on: September 06, 2013, 02:54:20 pm »
I'm not quite done yet, but on an AAZ, a line from a fabbed fitting on the bottom of the crankcase breather up to a tee on this on the VC
Then on over to this on the drivers side strutt tower
I'm actually just waiting for the Russell's stainless braided with blue AN fittings in 5/8 hose size.
Reply #13September 06, 2013, 06:18:19 pm
Gizmoman
  • 1301
« Reply #13 on: September 06, 2013, 06:18:19 pm »
Wow - nice work Mr!
Reply #14September 06, 2013, 07:09:31 pm
Jetmugg
  • 530
« Reply #14 on: September 06, 2013, 07:09:31 pm »
Looks like it should be a very clean setup, but is there really room for the water heater under your hood?   :D
