Author Topic: Is this an A/C or non A/C setup?  (Read 4469 times)
August 25, 2013, 10:51:55 am
BLVW
  • 22
« on: August 25, 2013, 10:51:55 am »
  Hey I found a good deal on a 1.6TD engine a guy was going to use for a samurai project but never got around to it.  The engine came pretty complete other than a few minor things such as an alternator.
   I was wondering if this alternator bracket/pulley setup is for use with an A/C compressor or not?   Because if not I was wanting to use it to remove my A/C setup on my pickup.   Thanks
Reply #1August 25, 2013, 10:59:23 am
Re: Is this an A/C or non A/C setup?
« Reply #1 on: August 25, 2013, 10:59:23 am »
Looks like the MK2 bracket, IIRC they were the same bracket for both a/c and non a/c. The difference was in the alt and pulleys.
Reply #2August 25, 2013, 06:27:15 pm
« Reply #2 on: August 25, 2013, 06:27:15 pm »
Yup MK2. Same as what my 88 non ac looks like.
Reply #3August 25, 2013, 07:01:43 pm
92EcoDiesel Jetta
Re: Re: Is this an A/C or non A/C setup?
« Reply #3 on: August 25, 2013, 07:01:43 pm »
Getting my spare low mileage Eco engine to run on the ground. Here's what the ac bracket looks like. I wire brushed the p/n so hopefully it is legible.
Reply #4August 25, 2013, 07:05:26 pm
« Reply #4 on: August 25, 2013, 07:05:26 pm »
MK2 AC and non AC main bracket is the same.
Reply #5August 25, 2013, 09:29:36 pm
92EcoDiesel Jetta
« Reply #5 on: August 25, 2013, 09:29:36 pm »
 how is the alternator and the tensiner different AC vs non AC?
Reply #6August 26, 2013, 06:58:47 am
« Reply #6 on: August 26, 2013, 06:58:47 am »
The AC alternator mounts the tensioning bracket in a different location allowing the alternator to be up, rather than down. I'm not sure exactly what the tensioner mounts to, I haven't seen an AC setup in a while (thankfully)
Reply #7August 26, 2013, 07:11:32 am
92EcoDiesel Jetta
« Reply #7 on: August 26, 2013, 07:11:32 am »
What does the non AC alt tensioner look like and how does it work? Is it klugy like the AC alt tensioner?
Reply #8August 26, 2013, 10:28:24 am
« Reply #8 on: August 26, 2013, 10:28:24 am »
It looks like this
Reply #9August 26, 2013, 05:34:02 pm
BLVW
  • 22
« Reply #9 on: August 26, 2013, 05:34:02 pm »
It looks like this
I also have this cogged adjuster but wasn't sure how it worked so thanks for the picture.  I'm able to get a reman non A/C alternator from the parts store.  So if I'm reading this all right, seems with the bracket ,  adjuster and 65a non AC alternator it should be all I need to get rid of my AC compressor.
   I was wondering how the belt setup worked tho,  I see there is two ribs on my crank pulley?
Reply #10August 26, 2013, 07:01:21 pm
« Reply #10 on: August 26, 2013, 07:01:21 pm »
You will probably need different pulleys to make it all happen. I'm not 100% on that though.
Reply #11August 26, 2013, 09:32:22 pm
  • 2931
« Reply #11 on: August 26, 2013, 09:32:22 pm »
Check the FAQ fora for non-AC conversion and you will find out alot about how to use that bracket for a non-AC setup.
