Recommendations for getting AAZ Valve Cover gasket to seal?
Topic: Recommendations for getting AAZ Valve Cover gasket to seal? (Read 4289 times)
August 12, 2013, 08:39:47 pm
Jetmugg
August 12, 2013, 08:39:47 pm »
I've been using an old VC gasket, knowing that I'd be pulling the valve cover multiple times to check timing, etc.
Naturally, it leaks like a sieve.
When I go to put in the new Victor Reinz gasket, what if anything should I do to ensure the best possible seal (factory stamped VC)?
RTV in the corners where the curved part of the front cam seal mates with the flat surface?
Hylomar all over?
What's the preferred setup to minimize leaks?
A Corrado style valve cover is not in the works for now - maybe next time around.
Steve.
August 14, 2013, 06:14:40 pm
Syncroincity
Re: Recommendations for getting AAZ Valve Cover gasket to seal?
August 14, 2013, 06:14:40 pm »
I ran a small bead of Great Stuff on mine, worked... well, great.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
August 15, 2013, 07:31:27 am
Jetmugg
August 15, 2013, 07:31:27 am »
Thanks. Did you hit both sides of the gasket with the great stuff, only 1 side (which side), or did you do away with the gasket altogether and just use the great stuff?
Any details would be appreciated.
Steve
August 15, 2013, 07:19:53 pm
Syncroincity
August 15, 2013, 07:19:53 pm »
I ran it between the head and gasket, a little in the cam cutouts, and also a thin coat between the gasket and cover on the low side of my engine... Vanagon tilted over at 50-degrees, so that side of the seal sees a lot of oil. It's very effective stuff, a bit pricey. I used a new Reinz rubber gasket.
JC McCavitt
'98 Jetta Wolfie
September 02, 2013, 09:29:15 am
stewardc
September 02, 2013, 09:29:15 am »
This is good news. I also have issues with my AAZ and even thought of drilling the lip and using a 1.6 cover.
September 02, 2013, 10:23:04 am
stewardc
September 02, 2013, 10:23:04 am »
I went lookingt for "Great Stuff". All I can find is a foam crack sealer. That would be very hard to use, and non oil-compatible. Comments
September 02, 2013, 11:30:41 am
September 02, 2013, 11:30:41 am »
Check out Right stuff.
Round 2
September 04, 2013, 04:57:40 pm
Syncroincity
September 04, 2013, 04:57:40 pm »
Quote from: theman53 on September 02, 2013, 11:30:41 am
RIGHT!
Small black & white can... Not the foam. Sorry!
JC McCavitt
'98 Jetta Wolfie
September 22, 2013, 08:45:44 am
DogDiesel
September 22, 2013, 08:45:44 am »
Not sure on your engine, but on my AAZ, the valve cover gasket has to be installed first, because it has several rubber tits that align it into holes on passenger side. Installed the gasket then the cover. It would leak if the near 10mm tits were just squashed. I used the same RUBBER gasket, with no sealer and absolutely no leaks.
September 23, 2013, 02:38:45 pm
stewardc
September 23, 2013, 02:38:45 pm »
RIGHT STUFF is the BOMB. Installed a new cover with RS on both sides....NO leaks. Thanks guys !
