Author Topic: WTB: 1.6td oil return line  (Read 4648 times)
July 21, 2013, 09:24:56 am
wut_cel
  • 34
« on: July 21, 2013, 09:24:56 am »
Any condition, as long as the flange and fitting are in good shape.
Reply #1July 21, 2013, 12:51:48 pm
Re: WTB: 1.6td oil return line
« Reply #1 on: July 21, 2013, 12:51:48 pm »
MK1 and MK2 have different return lines. That is transverse I don't know about the quantum/dasher setup but I would assume you need to list what car you are draining the turbo from.
Reply #2July 21, 2013, 03:15:45 pm
« Reply #2 on: July 21, 2013, 03:15:45 pm »
It matters what pan it is going to correct?
Reply #3July 21, 2013, 05:45:58 pm
« Reply #3 on: July 21, 2013, 05:45:58 pm »
Yes I believe so. The pan fittings had different angles that they come into the pan at.
Reply #4July 21, 2013, 06:56:21 pm
« Reply #4 on: July 21, 2013, 06:56:21 pm »
Yes
Reply #5July 22, 2013, 06:09:18 pm
wut_cel
  • 34
« Reply #5 on: July 22, 2013, 06:09:18 pm »
i need a line for a mk2, pans fitting is at the 11 o'clock position. I assume that I have an early mk2 td?
Reply #6July 23, 2013, 12:49:10 am
  • 2932
« Reply #6 on: July 23, 2013, 12:49:10 am »
Do you have one with collapsed flexible tube in the middle or none at all?
 The flexible part can be replaced with silicone tubing.
Reply #7July 23, 2013, 12:24:47 pm
wut_cel
  • 34
« Reply #7 on: July 23, 2013, 12:24:47 pm »
It has a flex pipe in the middle. I'm looking for a spare to rebuild and put on my daily driver.
