Author Topic: Egt temps  (Read 4019 times)
July 20, 2013, 02:09:53 pm
homerj1
  • 433
Egt temps
« on: July 20, 2013, 02:09:53 pm »
For those of you who have egt gauges - just wondering what egt temps  are you running on the highway?
Not sure of rpms ( but I suspect 3300ish), on a 32 deg C day, my egt's were around 430 C ( 806 F) steady driving and on a pedal to the metal, up a long hill I hit 545 C (1013 F).
This 1.6td, fuel screw turned up, no intercooler, auto trans.
I'm clearly safe egt temp wise?
Reply #1July 20, 2013, 10:13:23 pm
Re: Egt temps
« Reply #1 on: July 20, 2013, 10:13:23 pm »
Is your probe pre-turbine or post-turbine.  If pre-turbine, then you are safe.  If post-turbine then you would have to calculate the pressure drop and consequent temperature drop across the turbine in order to know if you are safe...
Reply #2July 21, 2013, 02:22:49 am
homerj1
  • 433
Re: Egt temps
« Reply #2 on: July 21, 2013, 02:22:49 am »
I'm pre-turbine.  Yes, I'm safe - lol!!   ;)
What is the limit temp-wise pre -turbine? - as there seems to be a wide range of numbers out there.
Reply #3July 21, 2013, 06:43:41 am
bbob203
  • 1789
Re: Egt temps
« Reply #3 on: July 21, 2013, 06:43:41 am »
1300 is pushing it.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4July 21, 2013, 02:10:54 pm
Re: Egt temps
« Reply #4 on: July 21, 2013, 02:10:54 pm »
RPM will have little to do with it, at 3000 RPM engine braking, I'll see 200F, climbing a hill at full load it will hit 1400.
Coolant temp climbs if I don't stay below 1250.
700-1100 on flat ground at 75 depending on wind, standing water,etc.
Reply #5July 21, 2013, 07:59:06 pm
Re: Egt temps
« Reply #5 on: July 21, 2013, 07:59:06 pm »
If I start off from my buddies, I climb out of a Valley immediately from his place.. I can be not reading on the water gauge, and by the top (maybe 2 kms..) the water temps are up to 185F! haha
She blows some heat, with that k03 being so small.
