General Information
Upgrades (non engine related )
Intercooler Piping
Topic: Intercooler Piping (Read 10847 times)
June 27, 2013, 01:34:15 pm
homerj1
Intercooler Piping
June 27, 2013, 01:34:15 pm »
I've figure out what
not
to use for turbo to intake piping.
So what can I use that is moderately cheap?
Will be pulling the piping and intercooler off my retired AHU, but I suspect that the piping may not be really usable with out some jigging.
June 27, 2013, 02:55:17 pm
Re: Intercooler Piping
June 27, 2013, 02:55:17 pm »
Exhaust pipe is plenty robust, and easy to work with.
June 27, 2013, 03:04:31 pm
homerj1
June 27, 2013, 03:04:31 pm »
Quote from: 745 turbogreasel on June 27, 2013, 02:55:17 pm
I was thinking of using exhaust pipe, but I had concerns about rust forming on the id. of the exhaust pipe? Vs -using alum., plastic or stainless for piping?
June 27, 2013, 03:36:01 pm
June 27, 2013, 03:36:01 pm »
http://www.siliconeintakes.com/product_info.php?cPath=19&products_id=767&osCsid=61ede2c748c37e075f81a3ef1cce299e
Round 2
June 27, 2013, 07:07:19 pm
June 27, 2013, 07:07:19 pm »
Most diesels have enough oil in the intake it is unlikely for rust to show up.
Unless you decide to use old rusty pipe to start with, then you get what you deserve.
August 21, 2013, 04:58:20 am
jaed_43725
August 21, 2013, 04:58:20 am »
If you use exhaust piping just have it powder coated.
August 21, 2013, 08:15:48 pm
August 21, 2013, 08:15:48 pm »
If rust forms on the ID of the pipe.. you have water in your engine.. get it checked out
August 21, 2013, 08:33:36 pm
August 21, 2013, 08:33:36 pm »
It's pretty normal to have water inside your engine, and I don't just mean the stuff in the coolant
August 21, 2013, 08:40:37 pm
August 21, 2013, 08:40:37 pm »
In the path between filter and the head?
I know for sure exhaust side of things..
August 21, 2013, 09:21:07 pm
August 21, 2013, 09:21:07 pm »
Water accumulates in your oil due to condensation. This is one of the main reasons why driving with a stuck open thermostat is a bad idea. Typically the oil gets up to temp and the water is boiled off and escapes through the crankcase vent (into the turbo, through the IC tubing then out the exhaust). Given just how oily our diesels are, and that most all of us own them because we drive them for more than 2 minutes at a time, I don't think rust would be an issue if the car doesn't sit for extended periods of time.
August 22, 2013, 09:19:00 am
homerj1
August 22, 2013, 09:19:00 am »
Thanks for all the help!
Although intercooler stuff will have to wait, as I still need to get one & best of all I just shelled out $250 plus for a starter for my 1.6td automatic..........ouchies......
Reply #11
August 22, 2013, 05:40:52 pm
Reply #11 on:
August 22, 2013, 05:40:52 pm »
WOW. Better be plated with something good.
You better install a new starter bushing too as even a 250.00 unit will die if the old one is worn
Round 2
Reply #12
August 22, 2013, 07:32:16 pm
Dakotakid
Reply #12 on:
August 22, 2013, 07:32:16 pm »
As I recall, those don't utilize a bushing. It has been awhile.
Years ago (15?), I bought the only auto diesel starter that VW showed on it books in North America. And, I paid over $325 at THAT time with dollars that actually had some value. Those starters are in a very hot, vulnerable spot. Sure hope you still have a heat shield in place. Otherwise, that starter will not last long.
I think I saw one of these starters on ebay last week. The problem is....you never know if they are any good....and, they are usually not. They weigh about 40 lbs. Boat anchors.
Reply #13
August 22, 2013, 07:34:09 pm
Reply #13 on:
August 22, 2013, 07:34:09 pm »
The auto starters are the same as many other auto starters. Built in bushings in their own nose cone.
If you can get one for cheap.. a starter/alt/generator place can likely rebuild them for under $100.
Reply #14
August 23, 2013, 01:50:27 am
Reply #14 on:
August 23, 2013, 01:50:27 am »
I took my 'weak' starter apart, cleaned and regreased the reduction gears, and had way better cranking speed.
General Information
Intercooler Piping
