I use them on my old cars ever since last april when a family member overheated and locked up my turbo diesel jetta
Even though I instructed a million times to pay attention to gages. She watched the low coolant level light go off, and then the temps rise and decided to just drive over the next hill before pulling over and locked it up. Limped it home with water spraying out the reservoir and trying to overheat. Engine is still on the shelf and doesn't appear to have scuffed cylinder walls or a warped head, not even cracks between the valves!
Anyway that is my story
I also suggest the little boxes they have to mount each which makes the profile larger but I learned the hard way its not good to have them loose and bouncing around.
I use an aircraft alarm as the aux alarm I got off ebay. Annoying.
I use 3 seperate gages because they told me that the unit cannot monitor each input at the same time
So you can switch over but that doesn't do any good when driving or split second problems.
I have oil pressure, water temp and egt, which can double for boost if you care to monitor that once in a while.
