For Sale/Looking For
Parts for Sale/Wanted
Ecodiesel Air box
Topic: Ecodiesel Air box (Read 5436 times)
June 15, 2013, 06:20:53 am
VTPSD
Ecodiesel Air box
June 15, 2013, 06:20:53 am »
I have a complete airbox from my ecodiesel. In good shape, comes with a nearly new Mann filter. $40 plus shipping.
-1991 audi 90 quattro with AHU tdi, r520's holset he211
-1990 audi 90 quattro, holset turbo, 11 second quarter mile demon
June 15, 2013, 10:08:05 am
Re: Ecodiesel Air box
June 15, 2013, 10:08:05 am »
Please post a picture
Interested.
June 17, 2013, 06:37:46 am
VTPSD
June 17, 2013, 06:37:46 am »
will post a picture tonight. It is just the box, not the intake tube to the turbo. Pic will show what is included for clarity.
June 17, 2013, 03:08:35 pm
June 17, 2013, 03:08:35 pm »
Thank-you, I am needing a box that will work for a custom air box location. I can fab the tubing.
June 17, 2013, 05:29:48 pm
VTPSD
June 17, 2013, 05:29:48 pm »
June 24, 2013, 10:43:59 am
VTPSD
June 24, 2013, 10:43:59 am »
previous sale fell through, still have this.
June 25, 2013, 05:34:47 am
Gizmoman
June 25, 2013, 05:34:47 am »
Can the lid be flipped around to point the intake in the opposite direction?
I know you're not an air filter expert but what is your opinion on using this to filter a 1.9?
Thanks,
June 25, 2013, 12:45:33 pm
June 25, 2013, 12:45:33 pm »
There is a secondary inlet to the ECO from the metal snoot that draws air from near the exhaust manifold. No need to flip the box, just open the flapper (usually vacuum controlled) and block the front inlet.
When using the front-facing inlet, there should also be a larger baffle that wraps around the headlight. The top portion is seen in the FS post, that piece can be removed to access the headlight bulb.
I put an ECO airbox in my 86TD, I think it is tuned to reduce intake noise at the higher RPMs. Seems quieter on the highway to me. The stock 86 intake draws air from the fender, which resonates.
The ECO airbox also takes the bigger 16V gasser filter.
June 25, 2013, 01:21:09 pm
damac
June 25, 2013, 01:21:09 pm »
Will this attach to mk2 turbo hose?
I did something very stupid and cut a hole in my mk1 fender to fit and lock in a mk2 airbox.
Today I didn't even think about it and drove in heavy rain and the car started skipping, I knew something was wrong right away. Water in airbox, filter and puddle up in the intake hose! Damn!!!
The only reason I cut is I didn't have much room in alternator area to just lay the box wherever it wanted to rest without the side fitting, and to secure it.
1985 turbo diesel jetta
June 25, 2013, 02:07:46 pm
June 25, 2013, 02:07:46 pm »
Yes, it does connect to the MK2 TD intake hose. But is is much bigger than the stock TD airbox, so if you had trouble fitting the MK2 airbox, the ECO may be too big. It is a tight squeeze in a MK2.
IIRC, the MK2 TD and ECO should both have a ~1/4" hole in the bottom to let out water/fluids.
June 25, 2013, 02:38:12 pm
damac
June 25, 2013, 02:38:12 pm »
I think the problem is the mk2 box even with the clip on piece removed has that casting that extends beyond the air filter dimensions so with it up against the inner fender it pushes the whole box over.
Water drain holes didn't do anything for my situation I guess. Filter is soaked, bottom of box was only half full of water, but water was sitting at the intake where the oil usually collects, man I got real lucky.
I thought I was being smart by getting the intake out of the engine bay!
Reply #11
June 26, 2013, 03:42:39 pm
GEE-BEE
Reply #11 on:
June 26, 2013, 03:42:39 pm »
imake the snorkel for THE MK1'S
Dealer : mk1autohaus on ebay
T2/T3/K14/K24
OR KO3
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #12
July 16, 2013, 07:59:56 am
VTPSD
Reply #12 on:
July 16, 2013, 07:59:56 am »
sold
Ecodiesel Air box
