Author Topic: WTB - crankshaft drive pulley (V-belt) for 1.5 / 1.6D  (Read 3868 times)
June 14, 2013, 12:47:56 pm
Jetmugg
  • 530
« on: June 14, 2013, 12:47:56 pm »
I'm putting my engine together from a variety of parts, and realized that I don't have a pulley that runs off the crankshaft for my 1.5/1.6 engine.  It's a 1.5 crank in a 1.6TD block.
I have the correct water pump and pulley, but don't have the crank pulley.
Any help is appreciated.
Steve.
Reply #1June 14, 2013, 02:25:49 pm
justiz00
  • 54
Re: WTB - crankshaft drive pulley (V-belt) for 1.5 / 1.6D
« Reply #1 on: June 14, 2013, 02:25:49 pm »
I have one but it has a balancer made on to it (TD model from 84 cy motor). I might have a standard but will have to look.
Added picture
Justice
« Last Edit: June 14, 2013, 02:53:05 pm by justiz00 »
Reply #2June 14, 2013, 03:01:58 pm
« Reply #2 on: June 14, 2013, 03:01:58 pm »
 .he needs a old style crank pully with real keyway.. do you have the keyway for the crank?
the only 1 i have is for a 1.6 longblock i have.. so not for sale.. but can get pic easy..
Reply #3June 14, 2013, 03:06:35 pm
justiz00
  • 54
« Reply #3 on: June 14, 2013, 03:06:35 pm »
Ok, good luck with locating.
Reply #4June 14, 2013, 07:34:02 pm
Jetmugg
  • 530
« Reply #4 on: June 14, 2013, 07:34:02 pm »
I think I found one ;D ;D
It's a stamped pulley that bolts to the cogged crank sprocket.  There is a "dimple" on the back of the pulley which indexes with a "bump" on the sprocket.
Steve.
Reply #5June 14, 2013, 08:08:47 pm
« Reply #5 on: June 14, 2013, 08:08:47 pm »
thats simple.. bbob owns it but got a non ac one right here.. ac has wider groove.. also have matching wp pully...
