For Sale/Looking For
Parts for Sale/Wanted
WTB B4 passat tdi pedals for mk2 tdi swap
Topic: WTB B4 passat tdi pedals for mk2 tdi swap (Read 4547 times)
June 12, 2013, 12:33:07 pm
the4ork
June 12, 2013, 12:33:07 pm »
i have a mk3 parts car, doesnt look like i can get the pedals in without lots of mods.
going to use the 02a so i have most of the hyd clutch setup, but i need the pedal assembly so i can bolt it to my firewall and have everything plug and play including cruise
thanks
Last Edit: June 13, 2013, 08:01:09 am by the4ork
June 12, 2013, 12:58:36 pm
bbob203
Re: WTB B3 passat tdi pedals for mk2 tdi swap
June 12, 2013, 12:58:36 pm »
make sure you get one with the cruise diaphragm on it so you can relocate the cruise diaphragm from under the hood to the pedal.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
June 12, 2013, 01:53:17 pm
June 12, 2013, 01:53:17 pm »
tdi... no cable... so no vac pod for cruise...
needs to be non abs with slave bracket too... tht part hard to obtain...
June 13, 2013, 04:22:23 am
June 13, 2013, 04:22:23 am »
Did you guys get a b3 with TDI? Ours started with b4.
June 13, 2013, 08:00:58 am
the4ork
June 13, 2013, 08:00:58 am »
i probably mean b4, dont know much about B series passats
June 13, 2013, 01:08:27 pm
Re: WTB B4 passat tdi pedals for mk2 tdi swap
June 13, 2013, 01:08:27 pm »
b3 hydro clutch... like roddo.. he needs hydro clutch.. the clutch master needs to match poedal too.. b3 different then b4... old is solid bar.. b4/mk3 is stamped into a c like shape.. hoe they affix 100% different.. he just needs b3-b4 prefeered non abs pedals and bracket for clutch master.. gotta have that bracket... you can mod the mk2 with a hole and bolt if you get that bracket...
before i install this b3 into the mk2 that i have ill get you pic...
June 14, 2013, 06:32:59 am
June 14, 2013, 06:32:59 am »
http://www.vwdiesel.net/forum/index.php?topic=33535.0
i made this thread for you... i am most likey going to fab a clutch master bracket... look at it.. lets talk..
