General Information
General
Windshield for 1984 vw Rabbit
Topic: Windshield for 1984 vw Rabbit (Read 6896 times)
June 07, 2013, 10:02:35 am
Dean Erickson
June 07, 2013, 10:02:35 am »
Anyone know where I can get one? I have checked with safelite and a few other. I can't find anyone that has a windshield for a 1984 vw Rabbit. The 84 is glued in unlike the 81 with a thick rubber gasket.
June 07, 2013, 10:44:31 am
srgtlord
Re: Windshield for 1984 vw Rabbit
June 07, 2013, 10:44:31 am »
You will need to purchase a rope-in windsheild and gasket as the glue-in seal is no longer available. The glass was available as far as I know fairly recently, but without the proper gasket your up a creek without a paddle...
June 07, 2013, 10:51:55 am
Dean Erickson
June 07, 2013, 10:51:55 am »
So you can do that? just change back to the thick rubber gasket and the 81 windshield and have it work?
June 07, 2013, 11:22:54 am
srgtlord
June 07, 2013, 11:22:54 am »
According to the internet, yes
June 07, 2013, 02:32:25 pm
rs899
June 07, 2013, 02:32:25 pm »
I am surprised this is NLA. Doesn't the Cabriolet up to '92 use the same glass? That's what I replaced my Rabbit P/U with. Seems like there should be a good market for it.
'91 Jetta 1.6 NA, '82 Caddy 1.6NA, '81 Cabriolet, 4 Mercedes OM616/617s , 2 Triumphs and a Citroen DS19 in a pear tree.
June 07, 2013, 05:18:53 pm
Dean Erickson
June 07, 2013, 05:18:53 pm »
Can anyone else confirm using the thick rubber gasket and 1981-82 windshield in my 1984 rabbit with a glued in windshield. I can't find any info on the internet about this working and the glass company's has no idea what I am talking about.
Thanks
June 07, 2013, 06:52:13 pm
June 07, 2013, 06:52:13 pm »
i was always told by people who clipped those cars.. aka fix totaled bunnys to make good bunnies back when they were new the lip the glass gets glued too is thicker/wider then the other kind... but ive never had glue one to find out.. so never mattered to me..
so if you pull your plastic trim from around the glass.. mat be metal on yours on th inside.. measure that lip.. then get a measurement from a rop in with no glass you will have the answere... but besides that the hole size is same..
June 07, 2013, 08:31:07 pm
Dean Erickson
June 07, 2013, 08:31:07 pm »
I have a old gasket from one of my old projects so I will try that. So do you know my truck from vwdieselparts.com. It was welded together. The front half is 1984 rabbit and the back half is 1981 truck. You were talking about cliping cars so I thought you may have seen my posts over there.
June 08, 2013, 04:32:47 am
June 08, 2013, 04:32:47 am »
nope... famly business thing from late 70s...
June 08, 2013, 07:36:31 am
Dean Erickson
June 08, 2013, 07:36:31 am »
Just found what I was looking for on vwvortex, This is what i found. You can change your urethane glued in windshield to the thick rubber press in seal, but you have to use a windshield and seal from a 81-81 rabbit. This is where I found it.
www.cabby-info.com/body.htm#windshield
June 08, 2013, 11:28:09 am
June 08, 2013, 11:28:09 am »
well i knew that bout glass.... rubber hard to get on proper glass.. add a inch.. no way in hell..
but you asked a queston on what i was told by people who cut them in the pillers to weld 2 cars together... i know vortex is full of smart people and all... so trust who you want... im just saying take a measurement as i aslo see tons of vortex smart people *** they cannot fit stuff as the seal is wrong/screwed up/off brand.. but for all i know is they tryin to fit a rubber glass in a glue in car...
never owned mk1 w/glue in,.. so ive never measured... what i do know is car #1 was 80 rear clip.. 83 front.. and how this came up in discussion... but it was back in 89... car was built in 85.. wrecked 2 more times after clip job.. then i got it to finish it off.. was also wrecked 2x before clip job.. po was drunk.. bro of garage secretary.. so kept gettin rebuilt..
Reply #11
June 21, 2013, 07:55:24 am
Reply #11 on:
June 21, 2013, 07:55:24 am »
http://www.vwdiesel.net/forum/index.php?topic=33461.0
fatman has interesting post there...
General Information
General
