Author Topic: pump fuel screw question  (Read 1958 times)
May 21, 2013, 08:24:41 pm
quickrip
  • 45
« on: May 21, 2013, 08:24:41 pm »
 I'm looking at buying a td pump with LDA to replace the stock ECOdiesel pump. The fuel screw has been taken out of the replacement pump. I'm wondering if it is ok to use the ECO pump screw on the turbo pump. Does anyone have the two pumps that they could compare screws on? I imagine they would be the same, but who knows. Other than this everything else looks to be in good shape.
ec
1991 ecodiesel
M&H modded td pump
M&H boost pin
arp head studs
saab intercooler
2.5" from the turbo back
Reply #1May 22, 2013, 06:48:47 am
Re: pump fuel screw question
« Reply #1 on: May 22, 2013, 06:48:47 am »
I'll see if I have a couple to compare.
In the meantime, I'd check the radial endplay of the input shaft of the "new" IP. More than .5mm could be an issue.
Reply #2May 22, 2013, 12:53:16 pm
« Reply #2 on: May 22, 2013, 12:53:16 pm »
Dey da same screws... at least on my ECO & TD.
Reply #3May 22, 2013, 01:15:58 pm
quickrip
  • 45
« Reply #3 on: May 22, 2013, 01:15:58 pm »
Thanks a lot for taking the time to check for me. I should have a td pump by sat. :D
I'm exited
1991 ecodiesel
M&H modded td pump
M&H boost pin
arp head studs
saab intercooler
