Author Topic: looking for an AAZ exhaust manifold and other options  (Read 4752 times)
May 14, 2013, 11:18:30 pm
zuhandenheit
  • 196
« on: May 14, 2013, 11:18:30 pm »
Hi All,
I've been having a very hard time finding an exhaust manifold for an install of an AAZ in a vanagon. The one that I have positions the turbo (K03) below the intake manifold (I think it's a TDI manifold . . . ).
Any suggestions? Are there any alternatives to the AAZ manifold that would work?
Reply #1May 15, 2013, 08:10:05 pm
Syncroincity
  • 727
Re: looking for an AAZ exhaust manifold and other options
« Reply #1 on: May 15, 2013, 08:10:05 pm »
Yeah, you have a TDI manifold. There's two different styles of AAZ manis: 4-bolt with a trapezoid shaped port, and 3-bolt with round hole. What does your turbo inlet have?
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #2May 16, 2013, 07:08:13 am
zuhandenheit
  • 196
« Reply #2 on: May 16, 2013, 07:08:13 am »
It's a three bolt, round hole port. I'd be happy to take some pictures, if there's any reason to do so.
Reply #3May 16, 2013, 12:19:50 pm
« Reply #3 on: May 16, 2013, 12:19:50 pm »
Does your turbo accept 3 bolts or does it have a stud and holes for 2 bolts where it mounts to the manifold?
Reply #4May 16, 2013, 03:42:26 pm
zuhandenheit
  • 196
« Reply #4 on: May 16, 2013, 03:42:26 pm »
The turbo has one stud and two holes for bolts.
Reply #5May 16, 2013, 07:24:18 pm
« Reply #5 on: May 16, 2013, 07:24:18 pm »
You have a TDI turbo then. I'd imagine it can be made to work but you should check that out first.
Reply #6May 16, 2013, 07:52:43 pm
zuhandenheit
  • 196
« Reply #6 on: May 16, 2013, 07:52:43 pm »
Oh - I see. Would it make sense to get an AAZ manifold and then remove the stud? Should I consider getting an 1.6td turbo and manifold? Are there any other manifolds that might work?
EDIT: I just realized that I had reversed things above.
Unfortunately, I just, finally, got my hands on a flange for this K03 turbo (one of Prothe's downpipe's)
Thanks for the help
« Last Edit: May 16, 2013, 08:36:23 pm by zuhandenheit »
Reply #7May 16, 2013, 08:08:25 pm
zuhandenheit
  • 196
« Reply #7 on: May 16, 2013, 08:08:25 pm »
Also, what significant differences are there between the two turbos?
