Author Topic: I think i lost a pulley somewhere....picture attached  (Read 8680 times)
April 29, 2013, 08:04:27 pm
Vohaul
  • 105
« on: April 29, 2013, 08:04:27 pm »
ugh...car is on a side road off the highway again......a big metal on metal noise...then the dash lights started flashin.....
got her pulled over and heres what i see....for reference, the power steering pump is on the lower right.....
im pretty sure thats where the harmonic balancer used to be.....we searched the highway..and found the power steering belt...but nothin else....what else is gone...
is this even fixable?.....interstingly enough, the car still idles fine...just heats up quick and no power steering:)
Paul
Reply #1April 29, 2013, 08:33:48 pm
masterbeavis
  • 88
Re: I think i lost a pulley somewhere....picture attached
« Reply #1 on: April 29, 2013, 08:33:48 pm »
Wow!  It looks fixable with another balancer/pulley. You'll need an EZ out and reverse twist drill bits to get the broken bolt out, a tap to chase the treads. Hopefully the bolt holes are not wallowed out. If they are, a new timing belt sprocket and crank bolt will fix that problem too.
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
Reply #2April 29, 2013, 08:51:24 pm
Vohaul
  • 105
« Reply #2 on: April 29, 2013, 08:51:24 pm »
ya, thanks, i didnt even see the broken bolt until you mentioned it.....am i missing a bol on the other pulley there as well...?
Reply #3April 29, 2013, 09:38:24 pm
wolf_walker
  • 1205
« Reply #3 on: April 29, 2013, 09:38:24 pm »
And one on the water pump pulley.  What in the hell killed all your bolts!??
Mentat Text Two
Reply #4April 29, 2013, 09:51:10 pm
Vohaul
  • 105
« Reply #4 on: April 29, 2013, 09:51:10 pm »
I have no clue......was a loud scraping noise and more than a few bangs as everything came apart..... Sigh
Reply #5April 30, 2013, 12:23:36 am
mystery3
  • 774
« Reply #5 on: April 30, 2013, 12:23:36 am »
Are there any animal parts or tire treads or any other foreign materials in your engine compartment?
Reply #6April 30, 2013, 05:51:18 am
« Reply #6 on: April 30, 2013, 05:51:18 am »
Did your ps pump lock up? If not I would say something got into the belts. If it starts and runs fine with no crank wobble then that is probably not it. Good luck.
Reply #7April 30, 2013, 09:45:26 pm
« Reply #7 on: April 30, 2013, 09:45:26 pm »
I'd be looking for a cat or cat hair under there someplace.
Reply #8May 01, 2013, 01:25:33 am
« Reply #8 on: May 01, 2013, 01:25:33 am »
Better check torque on the crank bolt.
Reply #9May 01, 2013, 01:55:41 am
bbob203
  • 1789
« Reply #9 on: May 01, 2013, 01:55:41 am »
do you have a clutched alt pulley?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #10May 01, 2013, 09:14:09 am
Vohaul
  • 105
« Reply #10 on: May 01, 2013, 09:14:09 am »
no but was in the process of getting one for it.....
honeslty, i might just call it quits with the diesel.....in addition to the new crank pulley, somethings wrong with either the glow plugs or the relay...it burns oil..and the body is rusty....i think maybe its time has come....sad maybe but i need a dependable daily driver...and this aint it anymore...
Reply #11May 01, 2013, 11:44:39 am
« Reply #11 on: May 01, 2013, 11:44:39 am »
it has gone too long with not enough maintenance then..
ive been driving a PARTS CAR for over 4 years now... problem free, logged over 100k miles on it..
yes, i bought the car as parts, but then i didnt have the heart to take it apart after i got it home, and got it running..
all it takes, is some basic maintenance, and these VWs will go for EVER..
Reply #12May 01, 2013, 01:33:24 pm
bbob203
  • 1789
« Reply #12 on: May 01, 2013, 01:33:24 pm »
It might not need the crank pulley fixed if its not messed up you can install the clutched pulley and you dont have to worry about that infamous aaz crank nose failure. glow plug system easy to troubleshoot. i would source a god used harmonic balancer and get 'er fixed it up
03 Jetta wagon TDi
Reply #13May 01, 2013, 02:56:01 pm
« Reply #13 on: May 01, 2013, 02:56:01 pm »
x2 on that...
Reply #14May 01, 2013, 04:42:38 pm
Vohaul
  • 105
« Reply #14 on: May 01, 2013, 04:42:38 pm »
it got regular maintenance and all...timing belt was just done along with a few other things....regular oil changes...but a while back, the serp belt snapped when my wife was driving it, and i think it mighta overheated....hasnt really been the same since....
