Author Topic: WTB: 1.6 Turbo Intake manifold Elbow  (Read 5568 times)
April 29, 2013, 02:39:38 pm
vwzzuk
  • 88
    • http://www.acmeadapters.com
« on: April 29, 2013, 02:39:38 pm »
I need a 1.6 Turbo intake elbow. I need the elbow that bolts to the top of a standard 1.6 turbo intake manifold.
Or a another 1.6 TD complete(manifold and elbow) intake manifold will work. I don't care if the black plastic valve is included or not.
thanks,
--dave
81 Rabbit Pickup, 1.9NA
85 Suburu Brat, 1.9TD AAZ
87 Suzuki Samurai, 1.6TD
92 Sidekick 4dr, 1.9TDI
Reply #1April 29, 2013, 05:31:54 pm
Re: WTB: 1.6 Turbo Intake manifold Elbow
« Reply #1 on: April 29, 2013, 05:31:54 pm »
Eco or true TD, they are different IIRC.
Reply #2April 29, 2013, 06:48:21 pm
Toby
  • 728
« Reply #2 on: April 29, 2013, 06:48:21 pm »
I have an extra. What do you want to pay for one? Or maybe I should ask what you expect to pay for one. ;<)
Reply #3April 30, 2013, 12:21:38 am
vwzzuk
  • 88
« Reply #3 on: April 30, 2013, 12:21:38 am »
I didn't realize that the ecco was different. Is it just that there is no boost/hose port? Mine is a standard 1.6TD intake but without the elbow on top. Its missing.
Toby: What did you want for your intake?
Reply #4April 30, 2013, 05:58:04 am
« Reply #4 on: April 30, 2013, 05:58:04 am »
I believe the eco has smaller hose openings on the turbo and the intake flange. I have had only the TD ones in a car. Now that I think about it I have one from the eco I made my intake out of. Also, the back of the casting of the intake on the eco is thicker and needing ground when using a k24 or t3 the housing hits.
Reply #5May 04, 2013, 09:59:15 am
vwzzuk
  • 88
« Reply #5 on: May 04, 2013, 09:59:15 am »
Toby, what do you want for your turbo intake?
Reply #6May 04, 2013, 01:28:39 pm
Toby
  • 728
« Reply #6 on: May 04, 2013, 01:28:39 pm »
Make me an offer.
Reply #7May 04, 2013, 05:32:58 pm
« Reply #7 on: May 04, 2013, 05:32:58 pm »
The compressor outlet is the same between the K24, T3 AND K14.
Reply #8May 04, 2013, 06:08:14 pm
« Reply #8 on: May 04, 2013, 06:08:14 pm »
what about the inlet to the intake manifold? I knew the K24 and t3 were the same, I haven't owned a K14. I was just thinking someone else had said that was the case.
Either way I have an elbow if the guy needs it.
Reply #9May 04, 2013, 09:22:34 pm
« Reply #9 on: May 04, 2013, 09:22:34 pm »
The compressor inlet is smaller but doesn't affect the metal intake manifold elbow.  ETKA shows the intake elbow to be the same between the MF and 1V engines.  They have a separate drawing for the MF and 1V turbocharger and only show the rubber elbow between the compressor and intake in the MF drawing.  I do not find another listing for that part for the 1V.
Reply #10May 05, 2013, 04:08:48 am
Patrick
  • 1034
« Reply #10 on: May 05, 2013, 04:08:48 am »
If you're close to me come and get one. I'll make you a heck of a deal....
Reply #11May 09, 2013, 04:42:01 pm
wut_cel
  • 34
« Reply #11 on: May 09, 2013, 04:42:01 pm »
I need one of these as well, PM me!
