Author Topic: FS 1.5l pistons & precups NOS  (Read 5359 times)
April 07, 2013, 11:37:50 am
RustyCaddy
  • 395
« on: April 07, 2013, 11:37:50 am »
Thought i might rebuild a 1.5l motor but plans have changed.
Set of 0.50mm over, made in Germany Mahle pistons, w/ rings, pins and circlips.  Some light oxidation in spots but should buff off.   Asking $250.00 USD shipped in continental USA.  Maybe last i'll ever see.
Also, 4 new precups to fit 1.5l (approx. 30.5mm diameter) but one is missing the ball bearing and another is miss labeled (?); might fit turbo head but made for NA (no triangles). Best offer.
Approx. 35,000 mile on rebuild 1.5l head, forwarned that it came off a high compression 1.5/1.6 hybrid that burned mostly biodiesel and veg oil, with oil return reducer, looks straight but i dont have machnists straight edge so selling as a core, no camshaft...best offer.
Pictures available on request.
« Last Edit: April 14, 2013, 01:03:52 pm by RustyCaddy »
Reply #1April 14, 2013, 01:04:58 pm
RustyCaddy
  • 395
Re: FS 1.5l pistons & precups NOS
« Reply #1 on: April 14, 2013, 01:04:58 pm »
ttt
Reply #2April 21, 2013, 10:04:16 am
RustyCaddy
  • 395
« Reply #2 on: April 21, 2013, 10:04:16 am »
ttt
Reply #3April 28, 2013, 10:50:38 am
RustyCaddy
  • 395
« Reply #3 on: April 28, 2013, 10:50:38 am »
ttt
Reply #4May 18, 2013, 09:46:44 am
RustyCaddy
  • 395
« Reply #4 on: May 18, 2013, 09:46:44 am »
btt
Reply #5June 02, 2013, 09:23:17 am
RustyCaddy
  • 395
« Reply #5 on: June 02, 2013, 09:23:17 am »
ttt
Reply #6June 03, 2013, 06:53:37 pm
« Reply #6 on: June 03, 2013, 06:53:37 pm »
if it has an oil return reducer INSTALLED IN THE HEAD, then it is a 1.6 head that was used on a 1.5D engine..
or do you mean that the oil return reducer for the block is included with the head?
the 1.5 head has a very small oil return passage already.. the 1.6 head has the bigger oil (would need reducers installed if not being used on proper block) return passages.
Reply #7June 04, 2013, 04:58:26 am
RustyCaddy
  • 395
« Reply #7 on: June 04, 2013, 04:58:26 am »
The head has the small oil return.  The reducer came from the VWparts forums sponsor.
