Author Topic: Coolant sensor  (Read 5330 times)
March 19, 2013, 11:33:59 pm
Vohaul
  • 105
Coolant sensor
« on: March 19, 2013, 11:33:59 pm »
Argh.....93 aaz jetta
The coolant sensor on my dash won't stop flashing.... Level is fine.... Temp is fine, car has power, no issues except the stupid light.... Replaced the overflow tank... No difference....
Does the plug going into the overflow tank on these go?
Thanks
Paul
Reply #1March 20, 2013, 09:03:36 am
wolf_walker
  • 1205
Re: Coolant sensor
« Reply #1 on: March 20, 2013, 09:03:36 am »
Did they have that coolant water/antifreeze ratio sensor in that model?  Seems like my 85 had that going on way back.  Little sensor with two pins in the coolant tank.
Mentat Text Two
Reply #2March 20, 2013, 04:49:41 pm
Vohaul
  • 105
Re: Coolant sensor
« Reply #2 on: March 20, 2013, 04:49:41 pm »
ya, i think thats the one....sensor is part of the overflow tank...with a plug going into the top of the "dome":)..i thought it was just a coolant level sensor...not a ratio
Drives me nuts...
This morning..start car...flashing...go to gas station...turn off...start car...no flash...1 hour drive..no flash...go for lunch...flashes again....and so on....
Reply #3March 20, 2013, 05:51:26 pm
wolf_walker
  • 1205
Re: Coolant sensor
« Reply #3 on: March 20, 2013, 05:51:26 pm »
I went through that years ago, freaked me out because I didn't have anyone to tell me it wasn't something terminal.
The A2 sensor is cheap, need o-ring too, if you haven't changed your coolant with a good mix it might be warning you
about something valid.
Mentat Text Two
Reply #4March 20, 2013, 06:27:26 pm
Vohaul
  • 105
Re: Coolant sensor
« Reply #4 on: March 20, 2013, 06:27:26 pm »
I thought the sensor was part of the overflow tank itself?
Reply #5March 20, 2013, 06:56:12 pm
wolf_walker
  • 1205
Re: Re: Coolant sensor
« Reply #5 on: March 20, 2013, 06:56:12 pm »
Not in the 85 I had, dunno bout yours.
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #6March 21, 2013, 08:42:53 pm
  • 2932
Re: Coolant sensor
« Reply #6 on: March 21, 2013, 08:42:53 pm »
 Make sure the sensor has a good ground.
 If not, the voltage will go high and trigger the light.
 If you can pull back the rubber boot and measure the voltage drop accross the sensor while the engine is running it will tell you what the sensor circuit is seeing.
Reply #7March 22, 2013, 08:13:49 am
Vohaul
  • 105
Re: Coolant sensor
« Reply #7 on: March 22, 2013, 08:13:49 am »
mine doesnt have a rubber boot as far as i can tell...it has a hard plastic plug (with clips ) that goes into the top of the overflow tank
Reply #8March 25, 2013, 09:16:52 pm
  • 2932
Re: Coolant sensor
« Reply #8 on: March 25, 2013, 09:16:52 pm »
So the wires connect to a hard plastic plug that disconnects from the sensor connector?
 Can you stick a volt meter to the wire ends while it's plugged in?
Reply #9April 04, 2013, 09:11:42 am
Vohaul
  • 105
Re: Coolant sensor
« Reply #9 on: April 04, 2013, 09:11:42 am »
only if i strip a little insualtion off the wires going into the plug......ive been running it for 4 weeks now at 120km + a day with no issues.....one day the light flashes...next day it doesnt....temp guage is working and never goes above 1/2 way..and thats only if im in downtown traffic....which is normal...most days it doesnt go past 1/4
on start up , thje light is off...usually after about 15-30 seconds, itll start flashing...if it hasnt turned on by then, it wont turn on the whole drive....
« Last Edit: April 04, 2013, 09:17:38 am by Vohaul »
