Author Topic: tdi swap questions  (Read 22551 times)
March 19, 2013, 03:54:44 pm
xxkoadyxx
  • 179
tdi swap questions
« on: March 19, 2013, 03:54:44 pm »
hey guys. iv search ect but i need some help with a coue connectors on my AHU mkE tdi swap. i know one or maybe two are for the intercooler?? but not sure which ones.. here are the description of the wires. main color first followed by small color (stripe)
2 wire one blue on grey solid. brown connector
2  wire orange/blue and blue/yellow
2 wire one brown and one brown and red.
D Shape 2 wire one brown one blue and red
2 wire bigger connextor brown/red and blue/red
« Last Edit: April 08, 2013, 05:20:55 pm by xxkoadyxx »
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #1March 19, 2013, 05:54:32 pm
410
  • 581
Re: tdi swap questions
« Reply #1 on: March 19, 2013, 05:54:32 pm »
http://www.haywood-sullivan.com/vanagon/TDI/1996_Jetta_TDI_wiring_LONG4.pdf
There are a couple differences depending which year the car was but this should help you out with those lonely connectors with no homes.
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles.  Sold!
Reply #2March 21, 2013, 06:09:04 am
xxkoadyxx
  • 179
« Reply #2 on: March 21, 2013, 06:09:04 am »
yea doesnt make any sense to me. alot of them i cant find the color combination. not the orange wires could be yellow.. but still dont seem to find correct one..
Reply #3March 21, 2013, 08:08:07 pm
410
  • 581
« Reply #3 on: March 21, 2013, 08:08:07 pm »
Can you take a picture of the connectors and post?
Reply #4March 22, 2013, 06:07:36 am
xxkoadyxx
  • 179
« Reply #4 on: March 22, 2013, 06:07:36 am »
ya i can do that. ill go out a littlelater and take pics. currently just and a foot of snow dumped on us :(
Reply #5March 22, 2013, 04:51:54 pm
xxkoadyxx
  • 179
« Reply #5 on: March 22, 2013, 04:51:54 pm »
here we goo..pics.
First one. these ones are togather and are up towards the rain tray. ones n75 maybe?
This one is over by where the air box would be..
Not sure what this is.. something vacumme related?
And this big one is under my dash.. no idea what it is for.. because there are no connectors there to plug into it
This 3 wire one (this part is from a passat tdi harnesss..)
These four down by the shifter..
not sure if these pictures are clear enought.. my car is a 93 golf 1.9TD with a TDI swap.. The harness is NON AC and my car had AC so that has to be deleted.. Also does anyone have a diagram for the vacume lines? the ones that come off the brake booster? and boost lines?
thanks very much guys  :-*
Reply #6March 24, 2013, 07:55:40 am
bbob203
  • 1789
« Reply #6 on: March 24, 2013, 07:55:40 am »
Sell off the etdi stuff and go mechanical :D. A2resource.com is very helpful.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #7March 24, 2013, 07:59:57 am
xxkoadyxx
  • 179
« Reply #7 on: March 24, 2013, 07:59:57 am »
thatll cost way to much haha i think im ggetting it figured kut couple are for inate temp and another one for the n75 not sure what the "d" shaped one is for. also one is for the coolent bottle
Reply #8March 24, 2013, 12:10:29 pm
xxkoadyxx
  • 179
« Reply #8 on: March 24, 2013, 12:10:29 pm »
ok so i got the engine bay pretty much figured out.. now what about these litttle ones by the fuse box..
Coming from the engine bay
Though it was a ground but doesnt fit anywhere?
And this one... its for the AC/Fans but i dont have the male part anywhere.. and when i connect the black/red wires togather the fans work.. if not they dont..
And this one.. it comes from the relay.. but doesnt have a female connector..
No female either
Reply #9March 24, 2013, 02:09:41 pm
bbob203
  • 1789
« Reply #9 on: March 24, 2013, 02:09:41 pm »
d d shape looks like it's for 02 J transmission reverse light switch connector trying to see if you can trace it back and see if maybe somebody splice that 1 in somewhere. a lot of those connectors only have 1 mate.
03 Jetta wagon TDi
Reply #10March 25, 2013, 09:47:17 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #10 on: March 25, 2013, 09:47:17 am »
This is a power wire (not fused) I can tell because its Red without a stripe
the yellow connector wires are for the airbags IIRC
This is for the CEL and it needs to go to a junction box with the other grey/white wires (one for the cluster, one for the OBD-2 plug)
I think this is for the alarm module plug, most people by-pass it by connecting the two large starter wires together:
Reply #11March 25, 2013, 05:48:55 pm
xxkoadyxx
  • 179
« Reply #11 on: March 25, 2013, 05:48:55 pm »
hmm alright. helps. but that last one with the big connector is for the fan controls.. but it doesnt plug into anything and my fans dont work onless i jump the big black/red wires togather. my car doesnt have airbags soo i dont have to worriy about that. gonna go out tomorrow and look into that little brown connector and see what that goss now that i have an idea.
Reply #12March 26, 2013, 10:12:54 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #12 on: March 26, 2013, 10:12:54 am »
Reply #13March 27, 2013, 03:46:42 pm
xxkoadyxx
  • 179
« Reply #13 on: March 27, 2013, 03:46:42 pm »
yaa my car does not have that many relays.. mine dont have ac,or abs. or airbags. hmmm
Reply #14April 07, 2013, 07:01:15 am
xxkoadyxx
  • 179
« Reply #14 on: April 07, 2013, 07:01:15 am »
well, i got it running! now i have a couple problems now... glow ug light is flashing? oil pressure light is one, and coolent.. now i think i maaay have hooked up the coolent temp sensors wrong? one on flange and one on the top rad hose? also i had to jump 12 volts to the cut off as the glow plugs and the cut off didnt get power with key on... so once i jumped 12v to cut off, glow plugs worked and cut off.. anyone know why? also when i take the hand brake off, my gauge cluster shuts off.... also now i seem to have a brake fluid leak as the brake pedal goes to the floor and i added a full bottle to the resivor and same... not sure where its leaking as no signs yet..having a closer look today..
