Author Topic: tdi swap questions  (Read 22535 times)
Reply #30April 14, 2013, 07:11:52 pm
Re: tdi swap questions
« Reply #30 on: April 14, 2013, 07:11:52 pm »
Sorry no idea on the N75.. the older 1Z/AHU like I have had no such thing until the ALH.
It is likely the timing is whacccccck.
Reply #31April 14, 2013, 07:57:23 pm
410
  • 581
« Reply #31 on: April 14, 2013, 07:57:23 pm »
There is a valve similar to the n75 valve on the ahu but it has nothing to do with the egr.  But, there is an egr solenoid that is basically the same in design.  The only real way of deleting the egr without causing a fault is to have the egr deleted by remapping the computer.
Reply #32April 16, 2013, 04:42:10 pm
xxkoadyxx
  • 179
« Reply #32 on: April 16, 2013, 04:42:10 pm »
Ok i figured out the idle and reving issuse.. Now another question.. My car used to be a 1.9td and now where im going tdi, do i need to change the cluster harness also? Cause i am not getting any temp gauge..
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #33April 16, 2013, 07:23:22 pm
« Reply #33 on: April 16, 2013, 07:23:22 pm »
temp sensors changed from 1.9TD to 19TDI I believe. My TDI one was a 4 prong plug..
Reply #34April 17, 2013, 05:21:50 am
Tintin
  • 1279
« Reply #34 on: April 17, 2013, 05:21:50 am »
I' don't remember exactly if the temp gauge work with the AHU sensor, but the RPM will not if you pick it from the ECU. You need an AHU cluster or reflash the little chip in your AAZ cluster with an AHU cluster files. I can give you the files if you can or have someone to do it.
In the case you want to trouble shoot, I have the current flow diagram for those cluster.
Reply #35April 29, 2013, 03:19:35 pm
xxkoadyxx
  • 179
« Reply #35 on: April 29, 2013, 03:19:35 pm »
Ok guys. Got it running and driving it around.. But car seems like something is holding it back when i give it.. Half throttle or a little throttle and itll slowly get up to speed.. Heres a video.. Im leaning towards a bad maf..
The car :-)
Reply #36April 29, 2013, 05:47:14 pm
410
  • 581
« Reply #36 on: April 29, 2013, 05:47:14 pm »
If you can get it scanned, you'll have your answer or at least a direction to go in.  It might be your maf but without scanning it it's just a guess.  It could be your map as well.  Did I read somewhere that you don't have an obd2 port?
Reply #37April 29, 2013, 05:49:41 pm
xxkoadyxx
  • 179
« Reply #37 on: April 29, 2013, 05:49:41 pm »
No i do not have an obd port. I bought one but have to splice it in... Also i must add that there is no smoke at all.
Reply #38April 29, 2013, 08:47:30 pm
410
  • 581
« Reply #38 on: April 29, 2013, 08:47:30 pm »
Make it a priority to hook up that obd port.  There's very few wires including a power and ground and once hooked up you can retrieve codes with any obd2 code reader.  Someone correct me if I'm wrong but I remember only three wires on the VW side of the obd port needed.  Power, ground, signal.
Reply #39May 22, 2013, 05:20:44 pm
xxkoadyxx
  • 179
« Reply #39 on: May 22, 2013, 05:20:44 pm »
Wired up obd port and didnt work.. So i went back and rewired it agian and havent been able to use an obd scanner yet agian.. Also i just replaced the maf and that didnt really seem to change to much really.. Soo next thing is to change fuel filter.. Also could a muffler cause problems? Or is there no way that could happen? Running out of ideas on what it could be..
Reply #40May 23, 2013, 08:52:58 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #40 on: May 23, 2013, 08:52:58 am »
You need to breakout a multimeter and make certain you have all of the connections put together for the diagnostics.
Reply #41May 23, 2013, 09:01:53 am
« Reply #41 on: May 23, 2013, 09:01:53 am »
What are you using to scan it with? Not all readers can handle VWs. My cheapo unit couldn't anyways.
Reply #42July 11, 2013, 10:33:21 am
the4ork
  • 331
« Reply #42 on: July 11, 2013, 10:33:21 am »
all the maf does is operate the egr anyways...
Reply #43July 14, 2013, 07:23:02 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #43 on: July 14, 2013, 07:23:02 pm »
The MAF does a little more than operate the EGR I have two that were accidentally damaged in different manners and they both screwed up different things. Once caused crazy boost pressures and the other cause the car to smoke like a coal train with other drive ability issues.
