General Information
General
max output for aaz k14
Topic: max output for aaz k14 (Read 10866 times)
March 14, 2013, 09:52:29 am
bbob203
March 14, 2013, 09:52:29 am »
looking for definitive numbers on it. what's the max useable boost with an intercooler? how much hp will I make with it on a tdi with stock injects? with. 216 injectors?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
March 14, 2013, 09:55:15 am
Re: max output for aaz k14
March 14, 2013, 09:55:15 am »
i cant say for sure since i have never seen a compressor map for one, but i would guess its in the 100-150hp range. 150 is being optimistic.
March 14, 2013, 10:18:55 am
March 14, 2013, 10:18:55 am »
TDIMeister posted this on the TDIclub a whiles back
March 14, 2013, 10:44:33 am
bbob203
March 14, 2013, 10:44:33 am »
translation please lol
03 Jetta wagon TDi
March 14, 2013, 10:46:26 am
March 14, 2013, 10:46:26 am »
Well you need to know the output of your engine, via
This
website. And then plot that line graph on this map.
March 14, 2013, 10:50:04 am
March 14, 2013, 10:50:04 am »
Isn't that for a K24? Just guessing based on the '2464' part number...
March 14, 2013, 10:56:06 am
March 14, 2013, 10:56:06 am »
Says its a K14-2464.. ? i dunno. I trust the guy who posted it. TDIMeister knows his siht.
March 14, 2013, 11:09:39 am
March 14, 2013, 11:09:39 am »
930 millibars = 13.4885096psi
Beyond that, I got nuthin.
March 14, 2013, 11:12:08 am
March 14, 2013, 11:12:08 am »
Here is the same map with my guesstimated engine's eventual capabilities.. 200hp peak power at 5000 18.3 PSI. I accounted for SUPER cool intake temps because
I WILL
be running an AWIC setup.
Dot 7 is 5500.
Dot 8 6000.
So basically 5500 would be the redline at 18psi, the turbo would still be above 70% and not over spooling.. JUST BARELY not over spooling haa.
Last Edit: March 14, 2013, 11:13:47 am by 8v-of-fury
March 14, 2013, 11:38:25 am
March 14, 2013, 11:38:25 am »
Can you do a plot on the GT2056 as well? I have a feeling it's a very good turbo for the 1.9L engines in general, would be interested to see your plot on that compressor.
March 14, 2013, 11:43:50 am
March 14, 2013, 11:43:50 am »
That is the turbo I most want to get my hands on!!
This is the same plot
GT2056 200hp 19.4 psi
GT2056 225hp 23.6psi
4th dot is 3000 and it is just at the surge limit.. last dot is 6000 and is just over spooled. Would work well in practice from what it says on paper.
Garrett T3 50 trim 200hp 19.4psi
Reply #11
March 14, 2013, 12:09:56 pm
TDIMeister
Reply #11 on:
March 14, 2013, 12:09:56 pm »
The well-known mussel-shell curves of the compressor map is super-imposed with the engine's "swallowing" or "aspirating" curves, which are the nearly straight lines that go up and to the right. I can't even remember myself what application this turbo is for or where I originally posted this LOL, but it is definitely a K14.
This particular engine at rated power/RPM corresponds to the swallowing curve labelled "1,0". Without knowing much else about what engine this turbo was originally installed in, this turbo supports a mass flow rate of up to about 0.18 kg/s (read the lower X-axis label). I use a rule of thumb that a Diesel engine (I assume a TDI, but IDI should not be much different) requires about 10-12 lb/min (0.076-0.09 kg/s) of airflow per 100 HP peak power to operate relatively smoke free. I go through the math in detail
here
here
and
here
(but caveat
here
). So the short answer is that this turbo supports about 200 HP but the engine won't produce this much power unless it is able to aspirate this airflow (function of RPM, volumetric efficiency and displacement, equation is written out on the upper right of the map) within the boundaries of support boost pressure (pressure ratio, P2t/P1t) in the first place.
Reply #12
March 14, 2013, 12:27:24 pm
Reply #12 on:
March 14, 2013, 12:27:24 pm »
i would guess this is the turbo found on mercedes diesels. kkk turbos part numbers are actually their compressor size
2464, would be a 2.4" exducer and the inducer is 64% of that
so about 61mm exducer and a 39mm inducer.
so its somewhere between a 40 trim t3 and a 45 trim t3, definitely not the k14 from a vw.
General Information
General
