Author Topic: 67 Mercury Cougar, Diesel  (Read 12973 times)
January 21, 2013, 05:52:05 pm
Reply #1January 21, 2013, 06:45:44 pm
Re: 67 Mercury Cougar, Diesel
« Reply #1 on: January 21, 2013, 06:45:44 pm »
Wooooowee, that hits my sweet spot ;) Sadly not a diesel though.. and nowhere near the condition :(
Reply #2January 21, 2013, 06:54:57 pm
« Reply #2 on: January 21, 2013, 06:54:57 pm »
I saw this and thought of you Jeremy. Took a big leap to take a fairly stock car and cobble in a Mercedes Diesel.
Reply #3January 21, 2013, 06:56:16 pm
« Reply #3 on: January 21, 2013, 06:56:16 pm »
Honestly, the best thing that could have happened to it. I am a ford guy (obviously).. but they don't have a diesel as good as the OM617!
Reply #4January 21, 2013, 08:33:37 pm
« Reply #4 on: January 21, 2013, 08:33:37 pm »
Those are great little engines, I'm surprised you don't see more MB diesel transplants, at least where speed isn't the deciding factor.
Reply #5January 21, 2013, 08:40:27 pm
« Reply #5 on: January 21, 2013, 08:40:27 pm »
At least where speed isn't the deciding factor.
But they can easily do 300-375 ft.lbs which is comparable to a fairly modified V8, so I'd think itd do alright with moving the light Mercury around.
Reply #6January 26, 2013, 02:59:42 pm
CrazyAndy
  • 739
« Reply #6 on: January 26, 2013, 02:59:42 pm »
Hmmm good point.  Just another candidate I can add to the board for if I do my dream swap of a diesel engine into a VW bus/van.  A nice turbo I5, be it VA, Audi, or MB, would be great for pushing all of that boxyness.  They did it with the W123, and it's heavier!
OM617 + anything. Has anyone put these in a boat?
Reply #7January 27, 2013, 05:31:01 pm
« Reply #7 on: January 27, 2013, 05:31:01 pm »
its a SHAME that more companies didnt use OM617 engines..
Reply #8January 27, 2013, 06:01:57 pm
« Reply #8 on: January 27, 2013, 06:01:57 pm »
Here is My Mercedes with its 617.952.
The valve cover is off to do a valve adjustment.
It is a real moose compared to the 1.6TD.
Reply #9January 27, 2013, 06:22:57 pm
« Reply #9 on: January 27, 2013, 06:22:57 pm »
I shoulda bought the Wagon I was looking at :(
Reply #10January 27, 2013, 06:47:31 pm
« Reply #10 on: January 27, 2013, 06:47:31 pm »
These are definitely old school diesels. You roll up with the window down and they have that same clattery diesel sound. I can't hear the turbo though.
Reply #11January 27, 2013, 08:44:30 pm
« Reply #11 on: January 27, 2013, 08:44:30 pm »
I wish our engines were set up like these, a set screw for valve adjustments instead of shims.
Reply #12January 30, 2013, 04:57:43 am
rs899
  • 647
« Reply #12 on: January 30, 2013, 04:57:43 am »
Yeah, there's a lot to like about the OM616 and OM617 engines.  Easy valve adjustments.  No worries timing chain and cast iron head.  Mercedes chassis, as solid as they are, though, are a order of magnitude harder and more expensive to rebuild than the strut-based VW designs.
Reply #13January 30, 2013, 06:15:41 am
« Reply #13 on: January 30, 2013, 06:15:41 am »
Hi,
An order of magnitude is that to your mind twice, squared or maybe 10x as high?
I have not seen anything to support this.
It does have a drive shaft and a differential which are parts built into the vw transmission. It is pre-electronic for the most part. It uses a vacuum pump that does most of the functions that electronics do including shifting the transmission running the door locks and heater controls.
I have done some maintenance to mine every part was relatively inexpensive. For instance changing the cable to the hood was 10 dollars for the cable assembly and 4 dollars more for a new lever as mine broke. It takes 8 quarts of oil guess that is more. I put a new 6 dollar gasket on the cam cover when I adjusted the valves.
The fuel injectors and glow plugs are pretty much identical price points  to the VW IDI.
Reply #14January 30, 2013, 06:18:29 am
« Reply #14 on: January 30, 2013, 06:18:29 am »
The vacuum leaks are horrible on the Mercs, maybe more so on the gassers. I maintained an 82 300D for about 6 months and it seemed most everything I bought for it was "just a bit more" than VW. I never had anything less expensive than VW, but look at it realistically...VW were cheap economy cars and a Mercedes is a Mercedes.
