Author Topic: FS: rear main teflon seal and carrier. SOLD  (Read 4027 times)
January 01, 2013, 12:08:38 pm
« on: January 01, 2013, 12:08:38 pm »
FS: Rear main teflon seal and carrier. I bought it for the ALH and didn't need it when I installed the clutch. I have one for my 1.6 as well and don't want to keep it around until the next project.
39.00 shipped in the 48 states.
37.00 plus actual and hassle to everywhere else.
« Last Edit: January 03, 2013, 05:14:46 pm by theman53 »
Reply #1January 01, 2013, 03:20:44 pm
bbob203
  • 1789
Re: FS: rear main teflon seal and carrier.
« Reply #1 on: January 01, 2013, 03:20:44 pm »
Will it work for on a 1z
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2January 01, 2013, 04:40:38 pm
« Reply #2 on: January 01, 2013, 04:40:38 pm »
Pretty much every 8v gas or diesel from 75 to the ALH it will fit.
Reply #3January 02, 2013, 06:11:59 am
« Reply #3 on: January 02, 2013, 06:11:59 am »
BTW, the teflon seal has no spring in it so that it will not cut into the crankshaft near as bad. It is a bonus to the good sealing.
Reply #4January 02, 2013, 10:05:07 pm
  • 2932
« Reply #4 on: January 02, 2013, 10:05:07 pm »
I've never seen one before,.. and it even has a rubber seal built into where it sits against the oil pan.
Reply #5January 03, 2013, 05:14:55 pm
Re: FS: rear main teflon seal and carrier. SOLD
« Reply #5 on: January 03, 2013, 05:14:55 pm »
SOLD
Reply #6January 03, 2013, 07:30:22 pm
« Reply #6 on: January 03, 2013, 07:30:22 pm »
i never saw one before either, pretty cool, so these last longer or what?
Reply #7January 03, 2013, 08:25:57 pm
RustyCaddy
  • 395
« Reply #7 on: January 03, 2013, 08:25:57 pm »
45,000 miles later and the integrated rear seal that is on the truck motor has never lost a drop of oil as far as i can tell
« Last Edit: January 03, 2013, 08:28:16 pm by RustyCaddy »
Reply #8January 03, 2013, 09:30:21 pm
« Reply #8 on: January 03, 2013, 09:30:21 pm »
Yes, I learned about them from my ALH and CRSMP5. They have an install tool in the center and you have to let the seal sit for at least an hour before turning the crankshaft. The teflon has to relax around it. If you rush it, the seal will leak.
