Author Topic: Wtb mk2 3 point canada seat belts  (Read 7731 times)
November 19, 2012, 03:45:25 am
bbob203
  • 1789
« on: November 19, 2012, 03:45:25 am »
The stocks offer 0 protection as the no longer lock. Some ought to have a parts car with a set of these with trim and such.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1November 19, 2012, 04:38:52 am
Re: Wtb mk2 3 point canada seat belts
« Reply #1 on: November 19, 2012, 04:38:52 am »
Front or rear?
Reply #2November 19, 2012, 04:47:42 am
bbob203
  • 1789
« Reply #2 on: November 19, 2012, 04:47:42 am »
03 Jetta wagon TDi
Reply #3November 19, 2012, 04:52:31 am
« Reply #3 on: November 19, 2012, 04:52:31 am »
You don't need the receiver right?
I might be going to the yard and I know they have a mk2 there that is whole.
Reply #4November 19, 2012, 04:58:28 am
bbob203
  • 1789
« Reply #4 on: November 19, 2012, 04:58:28 am »
If that's the deal down by the ebrake then no I guess id just need the harness and associated hardware.
03 Jetta wagon TDi
Reply #5November 19, 2012, 05:13:24 am
jboogie13
  • 175
« Reply #5 on: November 19, 2012, 05:13:24 am »
if you pick two sets of them id like to buy a set as well  ;D
Reply #6November 19, 2012, 08:49:35 am
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Wtb mk2 3 point canada seat belts
« Reply #6 on: November 19, 2012, 08:49:35 am »
They aren't only in Canada... I have three point adjustable belts in the GLI parts car I have..  Not 4 sale tho.
Sent from my DROID X2 using Tapatalk 2
Reply #7November 19, 2012, 11:17:19 am
« Reply #7 on: November 19, 2012, 11:17:19 am »
pree 88 mk2....  88 went to airbag or passive belts..... usa dot thing.....
Reply #8November 19, 2012, 11:34:31 am
jboogie13
  • 175
« Reply #8 on: November 19, 2012, 11:34:31 am »
my 91 doesn't have airbags, was it optional? ???
Reply #9November 19, 2012, 11:51:50 am
« Reply #9 on: November 19, 2012, 11:51:50 am »
passive = latch to door/auto belts... so correct you seek normal ones from pree88... or non dot/usa things... since you lack airbags... now if 88+ with air bags.. you would have normal belts...
Reply #10November 19, 2012, 12:54:07 pm
bbob203
  • 1789
« Reply #10 on: November 19, 2012, 12:54:07 pm »
damn there is a 86 jetta at akron pull a part to.
03 Jetta wagon TDi
Reply #11November 20, 2012, 12:36:40 pm
« Reply #11 on: November 20, 2012, 12:36:40 pm »
i recently found out that height adjustible seat belts existed in mk2 cars...
my buddys imported 87 Jetta has height adjustible seat belts.. LOVE them..
Reply #12November 20, 2012, 12:39:13 pm
jboogie13
  • 175
« Reply #12 on: November 20, 2012, 12:39:13 pm »
think itd be possible to pull the mechanism out of an a3? next time i am at the junk yard ill pull the trim off the b pillar to see how different the track mounts for the adjuster.
Reply #13November 20, 2012, 06:27:49 pm
« Reply #13 on: November 20, 2012, 06:27:49 pm »
all mk2 have height adj for normal 3 point belts... has 2 8mm allen bolts, 6mm heads, that holds it to the piller... gotta have the trim and bolts.... even passats do this...
Reply #14November 20, 2012, 06:40:58 pm
« Reply #14 on: November 20, 2012, 06:40:58 pm »
Wow I never realized how crappy your seat belts were in the states!
