Author Topic: Wtb mk2 3 point canada seat belts  (Read 7732 times)
Reply #15November 20, 2012, 07:52:24 pm
jboogie13
  • 175
Re: Wtb mk2 3 point canada seat belts
« Reply #15 on: November 20, 2012, 07:52:24 pm »
Wow I never realized how crappy your seat belts were in the states!
what makes you think its just the belts that are crappy? ::)
Reply #16November 21, 2012, 11:37:07 am
« Reply #16 on: November 21, 2012, 11:37:07 am »
all mk2 have height adj for normal 3 point belts... has 2 8mm allen bolts, 6mm heads, that holds it to the piller... gotta have the trim and bolts.... even passats do this...
all mk2 have them? wanna change your answer about that?
should i go take pics?
there are 5 mk2s on my property currently...
not a single one of them has height adjust 3pt seat belts...
Reply #17November 21, 2012, 11:49:05 am
jboogie13
  • 175
« Reply #17 on: November 21, 2012, 11:49:05 am »
i think he means the mounting holes for them, pull back your b-pillar trim and i bet theres two unused threaded inserts for the height adjust mechanism
Reply #18November 21, 2012, 12:05:00 pm
« Reply #18 on: November 21, 2012, 12:05:00 pm »
yes, all mounting provisions are there...
like Chris said, you need the trim, and obviously the height adjustible part..
the height adjustible ones go up higher than the fixed ones, correct?
Reply #19November 21, 2012, 12:21:38 pm
« Reply #19 on: November 21, 2012, 12:21:38 pm »
i said height adj on all 3 point stock belts.... passive.. nope... all have mounting holes for height dj piece... cause they lack a fixed one... gotta have adj piece...
get a b3 passat w/motorized ones... unless your a 40+ waist the lap belt does not even rest on one side of your hip.. ot canadian ones so my son could have proper fitting seat belt up front..
Reply #20November 21, 2012, 12:29:55 pm
jboogie13
  • 175
« Reply #20 on: November 21, 2012, 12:29:55 pm »
i was just going to cut a slot in my stock trim if i found the height adjust piece
