General Information
General
mk1 strut housing nut stuck
Topic: mk1 strut housing nut stuck (Read 6170 times)
November 10, 2012, 05:08:53 pm
srgtlord
November 10, 2012, 05:08:53 pm »
Is there some sort of trick to unsticking a rusted strut insert nut?
November 10, 2012, 05:42:09 pm
Re: mk1 strut housing nut stuck
November 10, 2012, 05:42:09 pm »
Blue-wrench a.k.a. Gas-axe...
(MAPP, O/A)
November 10, 2012, 06:07:50 pm
srgtlord
November 10, 2012, 06:07:50 pm »
I will give the Ol' torch a shot
November 10, 2012, 06:19:25 pm
November 10, 2012, 06:19:25 pm »
If you are replacing the strut anyway, get it cherry red hit it with some penetrating and get the wrench on it. Works for me.
November 10, 2012, 07:56:12 pm
November 10, 2012, 07:56:12 pm »
My 36" pipe wrench never fails.
November 11, 2012, 04:54:56 am
srgtlord
November 11, 2012, 04:54:56 am »
On a 1992 cabriolet there are only 4 little indents for a punch to loosen the nut,
November 11, 2012, 07:46:49 am
November 11, 2012, 07:46:49 am »
Pipe wrench woot
November 11, 2012, 07:48:56 am
November 11, 2012, 07:48:56 am »
Quote from: srgtlord on November 11, 2012, 04:54:56 am
That's not going to work, those grooves are actually for a special tool that u use to undo the nut but eff the special tool use a pipe wrench it will *** it up some but life goes on
November 11, 2012, 05:54:45 pm
srgtlord
November 11, 2012, 05:54:45 pm »
Solved the problem with a newly aquired air-chisel
November 11, 2012, 10:11:14 pm
Moderator
4552
November 11, 2012, 10:11:14 pm »
Another excuse to buy tools you really need anyway. I love it.
November 12, 2012, 04:32:06 am
srgtlord
November 12, 2012, 04:32:06 am »
Did I need it, no , will I be able to remove a rusty nut in about 30 seconds...yes
Reply #11
November 12, 2012, 08:40:41 pm
Moderator
4552
Reply #11 on:
November 12, 2012, 08:40:41 pm »
You needed it, time is money. Either way you spend it. Now you can do all sorts of damage to home and car. Great for tile work. Removal anyway.
General Information
General
