Author Topic: AAZ-50 degree vanagon oil pan baffle-level question?  (Read 5680 times)
November 01, 2012, 06:38:56 am
tdihuntdawg
  • 27
« on: November 01, 2012, 06:38:56 am »
hey vanagoners regardless of oil filter,cooler,lines etc how much oil do you actually run in the pan ?  Also is anybody  running a baffle? It seems that a hard right hand turn would allow  oil to slosh up on the rotating assembly. I've got some ideas for a baffle that would allow oil to drain yet form a pocket to keep oil from sloshing up. keeping oil in pan and  around pickup would be good insurance especially in a syncro which might see extreme angles at times.  it would not  to be near the crank at all  but in the pan just above oil level and notched out for pickup and dipstick. thank-you GLEANERDAWG
« Last Edit: November 01, 2012, 06:57:16 am by tdihuntdawg »
Reply #1November 01, 2012, 05:20:59 pm
Gizmoman
  • 1301
Re: AAZ-50 degree vanagon oil pan baffle-level question?
« Reply #1 on: November 01, 2012, 05:20:59 pm »
Probably not much help but I don't have a pan on my 50 degree 1.9 Vanagon - not sure if it's needed.
Reply #2November 01, 2012, 05:49:18 pm
Syncroincity
  • 727
« Reply #2 on: November 01, 2012, 05:49:18 pm »
I haven't drained mine yet for the first time to see what the pan is actually holding (minus filters & hoses which I have plenty of)... no help, sorry. I am running the AAZ windage tray, your motor should have come with one, which reduces direct oil-to-rotating mass contact.
If you don't have one, they're available at diesel-friendly suppliers like AutohausAZ.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #3November 01, 2012, 05:50:54 pm
« Reply #3 on: November 01, 2012, 05:50:54 pm »
It's the same windage tray as found on the 2.0 ABA is it not?
Reply #4November 01, 2012, 06:07:00 pm
Syncroincity
  • 727
« Reply #4 on: November 01, 2012, 06:07:00 pm »
I *think* so... the oil pans (for cars) are identical, so it should be the same tray.
JC McCavitt
'98 Jetta Wolfie
Reply #5November 01, 2012, 07:24:09 pm
« Reply #5 on: November 01, 2012, 07:24:09 pm »
I've used the AAZ windage tray on a couple vanagon installs.
Reply #6November 02, 2012, 05:37:19 am
tdihuntdawg
  • 27
« Reply #6 on: November 02, 2012, 05:37:19 am »
Thanks for the replys, I checked the other day no windage tray but I did have the 36mm TD pump.
Reply #7November 03, 2012, 06:46:26 am
Gizmoman
  • 1301
« Reply #7 on: November 03, 2012, 06:46:26 am »
Paolo,
As I'm a bit new to all this stuff, I did some googling and ran across this:
http://www.autotech.com/product/oil-pans-pumps/10-115-220K.html?fromcat= - even comes with longer pan bolts.
Hard to believe the crank counterweights churning oil can actually reduce HP, but from what I've read it does. I didn't have one before but I will get one now.
I wonder if there is any other "bad" effect other than the loss of HP? Could the oil get so sloshed around that it stopped pumping for a sec?
Reply #8November 03, 2012, 04:53:43 pm
Syncroincity
  • 727
JC McCavitt
'98 Jetta Wolfie
Reply #9November 07, 2012, 04:34:27 pm
bridgetroll13
  • 15
« Reply #9 on: November 07, 2012, 04:34:27 pm »
Paolo,
If the oil gets picked up by the reciprocating mass of the crank and rods it can become emulsified with air and lose some of its lubricative properties. It could starve the pickup and it does reduce horsepower. It is common practice in "performance" applications to employ a crank scraper as well.
http://www.crank-scrapers.com/VW.html
Erik
'82 Westy, AAZ, AAP 5 spd
Thanks,
Erik
'82 diesel Westy, 1.9t AAZ, AAP 5 spd
Reply #10November 07, 2012, 06:51:06 pm
Gizmoman
  • 1301
« Reply #10 on: November 07, 2012, 06:51:06 pm »
Makes sense - thanks for the explanation.
I'll be adding one to my rebuild parts list.
