Author Topic: Wastegate Actuator for manual vane control  (Read 10943 times)
October 30, 2012, 01:44:06 pm
Swartzvw
  • 53
« on: October 30, 2012, 01:44:06 pm »
Do you guys think this actuator would work for the boost limiter in a vane control linkage setup like libbybapa's?
http://www.treadstoneperformance.com/product.phtml?p=769&cat_key=660&prodname=Wastegate+Actuator%2C+18psi
Thanks.
84 VW Rabbit w/ VNT 17
87 VW Jetta GL
Reply #1October 30, 2012, 01:45:44 pm
Re: Wastegate Actuator for manual vane control
« Reply #1 on: October 30, 2012, 01:45:44 pm »
what turbo you running it on?
you gonna be running it by its self, or with the linkages?
Reply #2October 30, 2012, 01:59:45 pm
Swartzvw
  • 53
« Reply #2 on: October 30, 2012, 01:59:45 pm »
Sorry yeah, VNT17 with linkages.
87 VW Jetta GL
Reply #3October 30, 2012, 02:10:50 pm
rodpaslow
  • 670
« Reply #3 on: October 30, 2012, 02:10:50 pm »
I ended up buying one like that, thinking like you did.  Those controller are made for a valve type wastegate NOT vane control.  They don't have enough movement for vane control.  I have a new vacuum can at home I got with the 17 I bought, I think I still have it - I'd be will to sell it cheap, but you'd need to change it to a boost type controller.
Reply #4October 30, 2012, 05:25:27 pm
« Reply #4 on: October 30, 2012, 05:25:27 pm »
how do they not have enough movement for vane control? they have a larger range of motion than the vane lever has..
Reply #5October 30, 2012, 05:56:06 pm
Swartzvw
  • 53
« Reply #5 on: October 30, 2012, 05:56:06 pm »
Thats what I was thinking too, the vane lever doesnt move very far.
87 VW Jetta GL
Reply #6October 30, 2012, 06:25:01 pm
« Reply #6 on: October 30, 2012, 06:25:01 pm »
IMO, that would work well.  In the mechanical vane controls I've built there has been a transition lever.  You can make the lengths of the arms on that transition lever appropriately sized so that the range of motion of the vane lever matches the range of motion of the boost can.
Reply #7October 31, 2012, 09:31:04 am
« Reply #7 on: October 31, 2012, 09:31:04 am »
thats exactly what i was getting at..
you make one arm have a variable length..
Reply #8October 31, 2012, 02:07:49 pm
rodpaslow
  • 670
« Reply #8 on: October 31, 2012, 02:07:49 pm »
The one I had only had roughly .050 movement.  you'd have to increase that as the vane control moves much more than that.  No biggy - I just think it's much easier to use what it came with, as far as ever needing replacement as well.
Reply #9October 31, 2012, 02:20:03 pm
« Reply #9 on: October 31, 2012, 02:20:03 pm »
.050" movement?!
no way, it was broken..
all my wastegate cans move like 1-1.5" if nothing is connected to them..
Reply #10October 31, 2012, 08:05:59 pm
Swartzvw
  • 53
« Reply #10 on: October 31, 2012, 08:05:59 pm »
I think ill get one and try it out.
87 VW Jetta GL
Reply #11November 02, 2012, 10:26:06 am
Swartzvw
  • 53
« Reply #11 on: November 02, 2012, 10:26:06 am »
Ended up ordering this guy. A little more expensive but comes with different springs to adjust opening pressure.
http://shopping.kinugawaturbo.com/kinugawabilletadjustableturboactuatorfitkinugawaturbotd05htd06sl2twinscroll518zhousing.aspx
We'll see how it works. Gotta figure out how to make all the linkages and brackets and what not now.
87 VW Jetta GL
Reply #12November 02, 2012, 11:03:27 am
« Reply #12 on: November 02, 2012, 11:03:27 am »
OMG! THANK YOU!!!
a gift from the gods.. just what i needed!
Reply #13November 02, 2012, 11:48:27 am
« Reply #13 on: November 02, 2012, 11:48:27 am »
Looks like a very nice unit.  Thanks for the link.
Reply #14November 02, 2012, 01:16:12 pm
Swartzvw
  • 53
« Reply #14 on: November 02, 2012, 01:16:12 pm »
OMG! THANK YOU!!!
You're welcome!
87 VW Jetta GL
