Author Topic: Coated/chromed injector lines ?  (Read 4384 times)
October 29, 2012, 07:28:12 am
stewardc
« on: October 29, 2012, 07:28:12 am »
I know someone on here has done it, but I can't remember who. I understand it's a tricky business as the nuts remain on the line and cannot be bound up in any way. Can anyone give me some suggestions?
Reply #1October 29, 2012, 08:36:51 am
92EcoDiesel Jetta
Re: Coated/chromed injector lines ?
« Reply #1 on: October 29, 2012, 08:36:51 am »
Get junk delivery valves and put them on the ends before chroming.
Reply #2October 29, 2012, 03:49:07 pm
stewardc
« Reply #2 on: October 29, 2012, 03:49:07 pm »
Wouldn't the chrome just weld everything solid?   ???
Reply #3October 29, 2012, 03:53:56 pm
« Reply #3 on: October 29, 2012, 03:53:56 pm »
kinda what i would think...
Reply #4October 29, 2012, 04:17:46 pm
« Reply #4 on: October 29, 2012, 04:17:46 pm »
3m makes a powdercoating masking tape. If you went to a chrome powdercoat you could get it pretty well handled. You might have to coat the nut first then tape the inside of it and the end of the line and then coat the line. It would be doable that way. You might be able to send them to a plater and have it zinc coated and the zinc wouldn't hold onto the nut as bad as other platings. IIRC the factory had them cadnium or zinc yellow plated.
Reply #5October 30, 2012, 05:55:27 am
justiz00
  • 54
« Reply #5 on: October 30, 2012, 05:55:27 am »
I don't know the exact thickness, but at work both the zinc and gold chromate (electrical and mechanical plating methods) is x.x microns thick (whatever is required). Good enough for corrosion protection but no "welding" presay.
Reply #6October 30, 2012, 07:01:41 am
« Reply #6 on: October 30, 2012, 07:01:41 am »
Yeah that is what I am talking. The zinc and zinc yellow dichromate like what is on bolts is the same. The yellow is just a dye. I know when we do bolts they have to do something to them, maybe anneal them, maybe it is a second heat treat. Whatever it is the treatment has to do with the integrity of the bolt as the zinc plating process weakens it initially.
Reply #7October 30, 2012, 03:46:42 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #7 on: October 30, 2012, 03:46:42 pm »
Might hydrogen embrittlement rain upon the parade? ???
Reply #8October 31, 2012, 02:09:11 pm
stewardc
« Reply #8 on: October 31, 2012, 02:09:11 pm »
Also a concern for sure. Surely someone has prettied up an old diesel ??
Reply #9October 31, 2012, 02:18:49 pm
« Reply #9 on: October 31, 2012, 02:18:49 pm »
saw me lotsa purty krome injector lines on youtube today..
guarantee you they never commercially made a set of chrome lines for a 6.5 GM idi, yet i saw some today  :P
Reply #10October 31, 2012, 03:12:11 pm
« Reply #10 on: October 31, 2012, 03:12:11 pm »
Assemble motor.
Dip.
Win ;D
Reply #11November 01, 2012, 09:05:37 am
Jetmugg
  • 530
« Reply #11 on: November 01, 2012, 09:05:37 am »
How about polished stainless steel lines?  With a really good polish job, it can be hard to tell the difference.
Steve.
Reply #12November 01, 2012, 09:58:52 am
stewardc
« Reply #12 on: November 01, 2012, 09:58:52 am »
Know anyone who sells stainless lines ????
Reply #13November 01, 2012, 10:36:28 am
justiz00
  • 54
« Reply #13 on: November 01, 2012, 10:36:28 am »
I would contact this company. They make steel and stainless lines and do custom work for the cummins guys. I am sure if they had a set of lines to work off of then that could be replicated in ss.
http://www.scheiddiesel.com
Reply #14November 01, 2012, 10:40:11 am
CarlosA
  • 139
« Reply #14 on: November 01, 2012, 10:40:11 am »
Nice quality custom stainless lines here - you wouldnt have to remove much material to polish them up. Same process for chrome and stainless - polish = removing material. Will cause the hex to not have a snug fit with a wrench, etc.
http://www.rocken-tech.com/Fuel_Lines.html
I have also been able to get zinc plated hardware to a near chrome shine .. more like an excellent aluminum shine. But that was with walnut shells and lots of tumbling.
