Author Topic: let's have a vote  (Read 10595 times)
October 24, 2012, 10:06:38 am
wdkingery
  • 494
let's have a vote
« on: October 24, 2012, 10:06:38 am »
Is this VB gasket, or clutch material?
Reply #1October 24, 2012, 11:50:14 am
Re: let's have a vote
« Reply #1 on: October 24, 2012, 11:50:14 am »
What are we looking at? It doesn't look like clutch material to me.
Reply #2October 24, 2012, 11:51:08 am
wdkingery
  • 494
« Reply #2 on: October 24, 2012, 11:51:08 am »
Valve body off a 700r4
Reply #3October 24, 2012, 01:13:20 pm
« Reply #3 on: October 24, 2012, 01:13:20 pm »
looks like the valve body gasket to me.
Reply #4October 24, 2012, 01:15:22 pm
« Reply #4 on: October 24, 2012, 01:15:22 pm »
gasket..
Reply #5October 31, 2012, 09:23:08 pm
CrazyAndy
  • 739
« Reply #5 on: October 31, 2012, 09:23:08 pm »
Gasket
Reply #6October 31, 2012, 09:27:30 pm
wdkingery
  • 494
« Reply #6 on: October 31, 2012, 09:27:30 pm »
Yeah that's what it ended up being.
Still not 100% happy with the shifts.
Gonna put an nv3500 5 speed in it when I get one.
6.2 diesel plus 5 speed manual could equal 30 mpg highway
Reply #7November 01, 2012, 02:59:54 am
« Reply #7 on: November 01, 2012, 02:59:54 am »
Maybe in a Corvette....
NV3500 is kinda weak for a 6.2, but I guess you can probably get 10 of them for the price of a 4500.
Do you have a diesel governor in it?
What's wrong with the shift feel?
« Last Edit: November 01, 2012, 03:02:58 am by 745 turbogreasel »
Reply #8November 01, 2012, 11:51:01 am
wdkingery
  • 494
« Reply #8 on: November 01, 2012, 11:51:01 am »
It's the original 700r4, so it has the diesel governor. It started having real high line pressure and delaying the 1-2, and when it finally shifted it banged. So I pulled the valve body and checked for a stickin tv valve.. Valve wasn't stickin, but the photo from the original post is what I found just above the tv. So I thought that was it. Put it all back together and now when cold, it shifts just right; second by about 5 mph and third around 20. Soon as the cold start drops off it holds first till 15-20 no matter what. Doesn't bang as bad (put a spring under the second accumulator) but still shifts real late. How long till a 230k mile 1989 700r4 craps out you know? So I'm hoping to stick a five speed in it, but getting the nv3500 is not easy in VA evidently
Reply #9November 01, 2012, 12:24:57 pm
« Reply #9 on: November 01, 2012, 12:24:57 pm »
That is a lot of miles.
Tried slacking the TV cable  adjuster a tooth or two?
Also  sometimes the gov gear apple cores  on those, probably worth a peek in there first.
PS. I'm starting to want a 700 instead of the 400 behind my 6.2.
« Last Edit: November 01, 2012, 12:28:25 pm by 745 turbogreasel »
Reply #10November 01, 2012, 12:32:04 pm
wdkingery
  • 494
« Reply #10 on: November 01, 2012, 12:32:04 pm »
unhooking the tv cable does nothing. I'll try the governor this weekend
Reply #11November 02, 2012, 04:14:47 pm
« Reply #11 on: November 02, 2012, 04:14:47 pm »
i WOULD NOT use a NV3550 behind a 6.2d
and theres no way you will ever see 30mpg from a 6.2 in any truck..
Reply #12November 02, 2012, 04:21:32 pm
wdkingery
  • 494
« Reply #12 on: November 02, 2012, 04:21:32 pm »
I don't  know if I would either.. But the nv3500 is the one I was speaking of. The truck got 24.3 going back forth on a 7 mile journey for 31 gallons, with the original, 230k 700r4 behind that 6.2.
Also, the nv3500 came behind the 4.3l v6 which made similar hp/trq and the behind the 5.0 v8 which beat out the 6.2 on both.
Wasn't until the 6.5 turbo that that they went to the nv4500
« Last Edit: November 02, 2012, 05:06:57 pm by wdkingery »
Reply #13November 02, 2012, 05:52:35 pm
« Reply #13 on: November 02, 2012, 05:52:35 pm »
they die behind stock 4.3L V6 engines tho..
they ALL DIE..
they had horribly weak syncros...
Reply #14November 02, 2012, 09:09:14 pm
« Reply #14 on: November 02, 2012, 09:09:14 pm »
I never have seen a nv3500 have a failure death. I have seen several of them and even several 4500 with syncros that were out between 2nd and 3rd. If you slowed your shift it would be fine, but never have I seen on leave someone stranded. I am not saying it would be a good or bad choice for the 6.2 but I think it is a better unit than you give it credit for.
