Author Topic: Mk I passenger engine mount bracket $75  (Read 6543 times)
October 17, 2012, 08:15:50 am
92EcoDiesel Jetta
« on: October 17, 2012, 08:15:50 am »
The old mount already taken out, ready to accept a new mount. bracket alone $75. I can install a new mount if you like, bracket + mount $120.  plus shipping.
Reply #1October 17, 2012, 12:06:45 pm
Re: Mk I passenger engine mount bracket $75
« Reply #1 on: October 17, 2012, 12:06:45 pm »
Someone buy this from him so he can afford a properly sized BFH for this type of work.
Reply #2October 17, 2012, 04:31:11 pm
92EcoDiesel Jetta
« Reply #2 on: October 17, 2012, 04:31:11 pm »
Dude, what are you trying to say?
Reply #3October 17, 2012, 04:39:38 pm
« Reply #3 on: October 17, 2012, 04:39:38 pm »
That hammer is too small ;)
Reply #4October 17, 2012, 05:42:28 pm
« Reply #4 on: October 17, 2012, 05:42:28 pm »
WAY SMALL And to top it off it is a Carpenters hammer no less.  Look to buy a nice 2 lb ball peen one when you sell this up.
Reply #5October 18, 2012, 07:05:41 pm
92EcoDiesel Jetta
« Reply #5 on: October 18, 2012, 07:05:41 pm »
That hammer was plenty big to knock out the old mount, and should be sufficient to knock in the new mount. I am not going to hit the mount directly with the hammer.  A copper bar will be between mount and hammer and I will take small taps to slowly drive it in. Finesse, not brute force, a BFG will not be needed. I'll let you know how it works out.
Reply #6October 18, 2012, 08:39:59 pm
« Reply #6 on: October 18, 2012, 08:39:59 pm »
I second the finesse part but with a larger hammer the small taps do more work and the whole thing goes in much faster.  When dealing with this situation and I have heated the bracket and cooled the mount in the freezer overnight time matters.   The idea is to get it done ASAP and a bigger ball peen hammer would do that for you.  Saves the forearm as well.
Just my method.  Do not use a copper bar, wonder what that is worth these days?, but use an old bearing race as noted by another in this thread.
DAS
Reply #7October 19, 2012, 08:03:24 am
92EcoDiesel Jetta
« Reply #7 on: October 19, 2012, 08:03:24 am »
DAS
I don't have an old bearing race that big but do have a copper bar 1/4" thick 1" W 6" long (high power AC buss bars that I have laying around) so I don't mushroom the mount. Sometimes you just have to make do with what you have laying around. In any case I'll let you know how it works out.
Reply #8October 19, 2012, 12:05:18 pm
« Reply #8 on: October 19, 2012, 12:05:18 pm »
You might be able to cut a piece of galvanized pipe off and use it instead.  Just get the diameters to match for the most part and get it down to the point it is flush,  pipe OD can be bigger than flange.  It helps to distribute the force of the drive.  Faster to tap side to side on then moving the bar around.
Reply #9October 25, 2012, 08:16:34 am
92EcoDiesel Jetta
« Reply #9 on: October 25, 2012, 08:16:34 am »
My first attempt at installing the new mount into the bracket was unsuccessful. I found a bearing of a big enough size and supported the bracket with 2 cinder blocks, liberally greased both the mount and the bracket before trying to hammer the mount in. The problem I encountered was that I was not able to get the mount started straight due to the slippery grease. I ran out of time and had to stop. Next thing to try is to clean off the grease on the first 1/2" and see if I can get it started. If that doesn't work, I'll try it in a big vise.
Reply #10October 25, 2012, 09:29:17 pm
« Reply #10 on: October 25, 2012, 09:29:17 pm »
I think you can pound on that arrangement till the cows come home and never make it work.  I only got success by freezing the mount and heating the bracket with a propane torch to make it expand.  No grease used.
Reply #11October 25, 2012, 10:45:43 pm
aximiliei
« Reply #11 on: October 25, 2012, 10:45:43 pm »
If i remember correctly, it has been a few years.  When I had to change mine I took a spare front motor mount cup bracket (the one that attaches to the front cross member) for a mk1 and placed that and the mount lightly tapped into position into the side bracket into a vise (should be roughly the same diameter) and cranked my vise and it slid in pretty nice.
Reply #12October 26, 2012, 05:35:18 am
RustyCaddy
  • 395
« Reply #12 on: October 26, 2012, 05:35:18 am »
If you take a grinding stone and shave just a little along the outer edge of the mount it help to center it and then drive it with a vise, ball joint compressor or a shop press.
Reply #13October 26, 2012, 01:11:39 pm
« Reply #13 on: October 26, 2012, 01:11:39 pm »
Reply #14October 27, 2012, 08:22:36 am
« Reply #14 on: October 27, 2012, 08:22:36 am »
My guess is that a big vice is not available.  Try beveling the front edge with a hand file of grinder then by just a bit to get it started.  45 degree bevel.
