Author Topic: will a diesel bolt up to a quantum syncro 5cyl trans?  (Read 11677 times)
October 13, 2012, 03:26:11 pm
bbob203
  • 1789
« on: October 13, 2012, 03:26:11 pm »
found a quantum syncro for 600 bones has 5cyl wasnt sure how it would bolt up if at all? 5speed...
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1October 13, 2012, 04:47:40 pm
Re: will a diesel bolt up to a quantum syncro 5cyl trans?
« Reply #1 on: October 13, 2012, 04:47:40 pm »
There is an Audi trans that has both  patterns, without that, no.
Reply #2October 13, 2012, 08:33:59 pm
rallydiesel
  • 1880
« Reply #2 on: October 13, 2012, 08:33:59 pm »
Isn't Quantum longitudinal and your Jetta's are transverse, so I would say no.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3October 15, 2012, 09:39:50 am
« Reply #3 on: October 15, 2012, 09:39:50 am »
an audi 2.0L 5 cylinder diesel, or Volvo 6 cylinder diesel are the only engines that bolt up to a 5 cyl trans..
Reply #4October 15, 2012, 09:51:45 am
  • 2931
« Reply #4 on: October 15, 2012, 09:51:45 am »
 That has nothing to do with the engine bolting to the trany.
 I would be nice if they made an adapter kit so we could easily build a quantum syncro wagon with a 1.6 TD.  ;D
Reply #5October 15, 2012, 11:10:34 am
« Reply #5 on: October 15, 2012, 11:10:34 am »
the 86-89 quattro trannies had both patterns i do believe..
Audi TD5 engines are not hard to find, and are tougher than a 1.6...
Reply #6October 15, 2012, 11:32:05 am
bbob203
  • 1789
« Reply #6 on: October 15, 2012, 11:32:05 am »
but are the parts as easy to get as a 1.6? this thing is 600 bucks and a 5 speed already so if what you say is true this would be a pretty darn easy swap.
03 Jetta wagon TDi
Reply #7October 15, 2012, 11:38:10 am
« Reply #7 on: October 15, 2012, 11:38:10 am »
a TD5 is just a 1.6D with an extra cylinder..
the manifolds, gaskets, crank, cam, pump, and stuff like that are the only things that are SPECIFIC to the TD5..
the internals are all identical to 1.6s, but with one more.. injectors are the same, but with an extra one.
you can also use lots of gasser 5 cylinder stuff on these engines as well.. (timing belt, water pump, seals, that sort of thing)
Reply #8October 15, 2012, 12:22:32 pm
bbob203
  • 1789
« Reply #8 on: October 15, 2012, 12:22:32 pm »
ah I see is the fuel economy the same?
03 Jetta wagon TDi
Reply #9October 15, 2012, 02:37:12 pm
« Reply #9 on: October 15, 2012, 02:37:12 pm »
Per cylinder it is, but with more displacement, you do better at low  RPMs, and there is no balance shaft.
Reply #10October 16, 2012, 06:13:40 am
bbob203
  • 1789
« Reply #10 on: October 16, 2012, 06:13:40 am »
The posting for this car says "runs drives needs a headgasket" To me that doesn't make any sense. I've never done a headgasket before is it something i could do on the spot with a bag o tools? so i could drive it rather than trailer it or have it shipped?
03 Jetta wagon TDi
Reply #11October 16, 2012, 06:44:28 am
bbob203
  • 1789
« Reply #11 on: October 16, 2012, 06:44:28 am »
so I talked to the owner. he said the po replace head gasket and machined the head to flaten it oit and re used the tty bolts so it leaks. ROR is this something I could maybe fix I knoe you've said you've re used tty bolts before.
03 Jetta wagon TDi
Reply #12October 16, 2012, 07:32:48 am
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
« Reply #12 on: October 16, 2012, 07:32:48 am »
86-89 are not dual bolt pattern...If that were the case I would have already put my AHU into my 87 4000CS quattro
....And if Audi TD5's aren't hard to find, how come I can't seem to find a head for mine?
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #13October 16, 2012, 10:05:36 am
lovinthedeez
  • 489
« Reply #13 on: October 16, 2012, 10:05:36 am »
I had a head gasket blow on my diesel swap in four different places.  Ran and drove great....for about fifteen minutes.  they can run but the heat gets into the coolant, and the temp needle just goes up up up.
Reply #14October 16, 2012, 12:58:49 pm
bbob203
  • 1789
« Reply #14 on: October 16, 2012, 12:58:49 pm »
How tough would it be to find a quatro trans for it?
03 Jetta wagon TDi
