Author Topic: Need new starter.. will 02J tdi starter fit 02A tranny?  (Read 4368 times)
September 30, 2012, 01:36:30 pm
steevz
  • 229
« on: September 30, 2012, 01:36:30 pm »
As the title says.. the gasser starter I used from my swap is failing fast.
Which TDI starter will fit 02A tranny?
Reply #1September 30, 2012, 01:38:30 pm
Re: Need new starter.. will 02J tdi starter fit 02A tranny?
« Reply #1 on: September 30, 2012, 01:38:30 pm »
1998 Jetta TDI had the 02A transmission.
Reply #2September 30, 2012, 07:59:57 pm
steevz
  • 229
« Reply #2 on: September 30, 2012, 07:59:57 pm »
Got a 2000 tdi starter and it works. Turns slow still.. maybe battery or else another bad starter.
Reply #3September 30, 2012, 08:09:19 pm
« Reply #3 on: September 30, 2012, 08:09:19 pm »
is the mating surface between the starter and the transmission crystal clean? It grounds ~400 amps through there, it needs to be spotless.
Reply #4October 01, 2012, 05:23:58 pm
« Reply #4 on: October 01, 2012, 05:23:58 pm »
Do a voltage drop test and have your battery load tested
Reply #5October 03, 2012, 05:16:58 pm
steevz
  • 229
« Reply #5 on: October 03, 2012, 05:16:58 pm »
I'll double check that, thanks.
The battery might also be weak, like 750ca 600cca or something piss poor like that. I"m going to grab a 950cca battery from work and see if it helps.
