Author Topic: I hope this isnt my i/p going south... video content  (Read 4742 times)
August 15, 2012, 07:20:08 am
bbob203
  • 1789
« on: August 15, 2012, 07:20:08 am »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1August 15, 2012, 09:15:49 am
Re: I hope this isnt my i/p going south... video content
« Reply #1 on: August 15, 2012, 09:15:49 am »
That is your timing belt rubbing on the side of your tensioner pulley, I can't recall.. Are they plastic or metal on the 1.6's?
Does the noise only happen at idle? or all the time?
Reply #2August 15, 2012, 10:10:53 am
Dakotakid
  • 1240
« Reply #2 on: August 15, 2012, 10:10:53 am »
Sounds like the bearing in the tensioner is gone.
Reply #3August 15, 2012, 11:00:03 am
bbob203
  • 1789
« Reply #3 on: August 15, 2012, 11:00:03 am »
hmm. the damn thing has less than 15kmiles on it. I've had this noise for awhile I just ignored it for some reason.
03 Jetta wagon TDi
Reply #4August 15, 2012, 07:07:58 pm
410
  • 581
« Reply #4 on: August 15, 2012, 07:07:58 pm »
I just had a car in where the metal timing belt shield was rubbing the cam pulley.  I loosened the two 10mm bolts on each side of the head that hold the shield on, pushed the shield towards the head and retightened.  The bolt holes are slotted.  Hopefully that's your problem too.
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles.  Sold!
Reply #5August 15, 2012, 07:32:54 pm
« Reply #5 on: August 15, 2012, 07:32:54 pm »
Can we get a picture of the relation of the belt to the tensioner pulley please and thank-you?
