Author Topic: Fan not working--Suggestions on where to start?  (Read 5076 times)
August 14, 2012, 03:55:08 pm
mtnbob
  • 738
« on: August 14, 2012, 03:55:08 pm »
My fan is not coming on. I think it started before I replaced the engine. Any suggestions on how to diagnose it, or where to start looking?
96 Subaru Outback Wagon
Reply #1August 14, 2012, 06:17:01 pm
bbob203
  • 1789
Re: Fan not working--Suggestions on where to start?
« Reply #1 on: August 14, 2012, 06:17:01 pm »
bust out the bentley there is good instructions on diagnosing fan problems.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2August 14, 2012, 07:29:33 pm
mtnbob
  • 738
« Reply #2 on: August 14, 2012, 07:29:33 pm »
hmmmm i'll look again
ty
Any luck on the metal pipe for the td cooling
Reply #3August 14, 2012, 07:35:06 pm
« Reply #3 on: August 14, 2012, 07:35:06 pm »
Easiest would be to check the wiring/connectors first.
Reply #4August 14, 2012, 07:42:10 pm
bbob203
  • 1789
« Reply #4 on: August 14, 2012, 07:42:10 pm »
ty
Im gonna go to jy tomorrow.
03 Jetta wagon TDi
Reply #5August 14, 2012, 08:36:11 pm
Dakotakid
  • 1240
« Reply #5 on: August 14, 2012, 08:36:11 pm »
Start at zee fuse, mon. 30 amp. Green.
Reply #6August 14, 2012, 08:56:50 pm
« Reply #6 on: August 14, 2012, 08:56:50 pm »
my 1st step.... hook up battery..
2nd unplug thermo switch on rad.. cross 2 wires with homemade jumper.. no run.. keep jumper in... this to be rehooked last.. y.. you will see..
3rd check fuse... if blown replace... fan on?? jumper will turn fan on... so this way as you check each part.. it will tell when fixed..
relay also on needs checked... but my 1st 3 steps above
« Last Edit: August 15, 2012, 06:20:54 am by theman53 »
Reply #7August 15, 2012, 03:30:42 am
mtnbob
  • 738
« Reply #7 on: August 15, 2012, 03:30:42 am »
ty
Reply #8August 15, 2012, 06:46:23 am
JessaBug
  • 112
« Reply #8 on: August 15, 2012, 06:46:23 am »
Wouldn't be surprised if it was the thermo switch. We put in a new one 2 years before our rebuild. All worked great. Put the engine all back in, switch was dead. We tried everything but that stupid switch because we thought there was no way it could be dead  >:(
Mine - BMP 20thAE GTI
His - '01 Jetta TDI
Our project: '84 Jetta TD
Reply #9August 15, 2012, 04:12:50 pm
Dakotakid
  • 1240
« Reply #9 on: August 15, 2012, 04:12:50 pm »
Well, ALL the above is good advice.
But, as some other obvious problems have arisen in the last couple days......are you sure the engine is warm enough to activate the fan cycle? Are BOTH radiator hoses getting good and hot?
Do you have a formerly consistent temp guage in this car?
Reply #10August 16, 2012, 12:43:55 am
mtnbob
  • 738
« Reply #10 on: August 16, 2012, 12:43:55 am »
Of course, I have the a/c model, so the wiring is 10x more complicated. Yes the temp gauge has always worked well, and the engine is warm enough to kick the fan on.
