Author Topic: feeler wtb b3 passat wagon diesel.  (Read 7075 times)
August 09, 2012, 07:55:39 am
bbob203
  • 1789
« on: August 09, 2012, 07:55:39 am »
looking to buy one soon. location of vehicle is no obstacle as long as you live within a few hours of an airport in the us or canada.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1August 09, 2012, 10:14:04 am
CdnVWJunkie
  • 309
Re: feeler wtb b3 passat wagon diesel.
« Reply #1 on: August 09, 2012, 10:14:04 am »
I've only ever seen sedan B3s here.  Did VW sell B3 AAZ wagons here?
Reply #2August 09, 2012, 10:55:04 am
« Reply #2 on: August 09, 2012, 10:55:04 am »
i has one... but i made mine... 1.6td... 020 even shoehorned in.... but not for sale...
Reply #3August 09, 2012, 11:53:31 am
« Reply #3 on: August 09, 2012, 11:53:31 am »
im not aware of VW sending any to this side of the pond..
Reply #4August 09, 2012, 02:07:34 pm
bbob203
  • 1789
« Reply #4 on: August 09, 2012, 02:07:34 pm »
I may end up going this route. did you have to make any custom mounts? Im hoping to find something canadian maybe. could I check yours out sometime when I'm visiting my folks in akron?
03 Jetta wagon TDi
Reply #5August 09, 2012, 08:06:11 pm
« Reply #5 on: August 09, 2012, 08:06:11 pm »
i 2nd exit in on i80... u drive right by..
020..... yes sort of... frame rail has to be cut.. 020 longer then 02a.. just bottom of it, half a inch.. shifter mount on rack... the shift tube nuuts cut, a z sorta shape piece made and splice tube back together, the shifter it taller and further back on a b3 vs mk2 so gotta get the rod lined up better..
mk2 pedals fit.. needs hammer mod where colum goes thru.. one spot is a tad tight..
tank.. supposedly a b4 tdi  WAGON float fits.. mk3 different.. never work... and sedan no work... else you gotta cut off the pump tube crap and make a solid tube up.. i used nylon line with clamps.. tank holds more then 20 gal.. ive done 21 a couple times...
Reply #6August 10, 2012, 05:28:34 am
bbob203
  • 1789
« Reply #6 on: August 10, 2012, 05:28:34 am »
bumped a thread in idi section pertaining to this topic.
03 Jetta wagon TDi
Reply #7August 10, 2012, 08:12:05 pm
« Reply #7 on: August 10, 2012, 08:12:05 pm »
so find any wagons on vortex? took me 35 hours over a 2 day weekend to take gas crap out, strip my sedan i had all the td stuff in (built that in 02, ran it for 4 years till i put it in wagon).. install diesel stuff in to wagon...
take a 4 day weekend off.. bring all stuff here and we get ya done up real quick... that was by myself.. i know required tricks.. got tig if your doing intercooler/stainless exhausst...
so something to think abt...
Reply #8August 11, 2012, 01:55:20 am
bbob203
  • 1789
« Reply #8 on: August 11, 2012, 01:55:20 am »
sounds like a plan probably take me at least a few months to get it all together. luckily I just got a second job so it we a little quicker to pull it off. what's a more suitable car a vr6 or 2.0
03 Jetta wagon TDi
Reply #9August 11, 2012, 05:15:33 am
« Reply #9 on: August 11, 2012, 05:15:33 am »
vr6 = 5x100 and +1 on suspention.. also for emissions a auto fail... no vw diesel for 93-96 till tdi in 96...
in 90-92 16v b3.... vw had 1.6 diesels in jettas/golfs so to cross plant a diesel in one just requires a but they had them in golf/jetta so dicking with epa regs not so bad if you live in a emisson requirement state..  just rember a eco diesel had cat.. na did not..
so do some reserch for your state to decide... my sedan was a 92, my wagon is a 90... if i was to ever sell it/require emissions i know i am covered... pluse got 3 more years till its 25 and theory is historical plates :) too bad i need 1 car to have normal plates... not driven my b3 in 18 months... kubvan been my travel car.. not needed a 3rd person seat in long time.. but its got plates/insurance... :P
work wise... vr6/16v.. same.. vr6 = electric speedo... 16v = cable...
ac lines... 16v hook right up to mk1/mk2 ac comp... vr6.. not.. :P but vr6 may hook upto tdi style ac comp with serp.. do not know 100% though..
id also do heater core during the build with flap refoam.. pull dash for wiring ease/pedal swap ease.. i had already done this in my sedan.. so swapped it too during the build on the wagon.. this is also a good time to swap to black carpet or better carpet if wanted... the grey/tan carpets suck/stain..
Reply #10August 11, 2012, 06:25:45 am
bbob203
  • 1789
« Reply #10 on: August 11, 2012, 06:25:45 am »
ill probably have the car registered in ohio. would like to use a hydro motor will actually probably use eco motor asf trans and eco exhaust i just put in my jetta and just find an N/a and trans to put back in it and sell the car. 16v chasis probably sounds better I more of a manual cable type of guy opposed to being all electrified and digital. I assume the world will be mad maxx in a few years so I make my car accordingly. ac don't know if I want it or not. did any of these b3's come with sunroofs? one thing I like having in a car.
03 Jetta wagon TDi
Reply #11August 11, 2012, 08:47:49 am
« Reply #11 on: August 11, 2012, 08:47:49 am »
most all have sunroofs... most have power locks/windows too... ive seen i think 3 or so over my life with manual windows/mirrors and 2 with no sunroofs... those were sedans... wagons.. cannot say ive not seen decked out..
i myself.. if you can.. find a 02a version.. reuse the 02a on diesel.. and if at all possible.. no abs.. abs sucks..
Reply #12August 11, 2012, 02:10:38 pm
Wayland
  • 364
« Reply #12 on: August 11, 2012, 02:10:38 pm »
I've seen more than one B3 Passat AAZ wagon for sale here on the West Coast of Canada, so they do exist. FWIW, the 93 Passat sedan I had was hands down the worst car I've ever owned. I ended up parting it out and scapping it after spending $1000s trying to keep it on the road. I'd never go near one again. OK, end of rant. :)
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #13August 11, 2012, 02:56:57 pm
bbob203
  • 1789
« Reply #13 on: August 11, 2012, 02:56:57 pm »
what was bad about it?
03 Jetta wagon TDi
Reply #14August 12, 2012, 05:20:16 am
bbob203
  • 1789
« Reply #14 on: August 12, 2012, 05:20:16 am »
how are the fifth ratios on o2a's. what 020 did you use?
03 Jetta wagon TDi
