Author Topic: Better fuel return hose  (Read 13409 times)
Reply #30October 30, 2013, 08:11:25 am
92EcoDiesel Jetta
Re: Better fuel return hose
« Reply #30 on: October 30, 2013, 08:11:25 am »
I think it's incorrect to say there is no fuel pressure in the return lines. Just the restriction of the small diameter line pushing fuel back to the tank results in some pressure . My guess a few psi, enough to pop the daisy chain lines if not a tight fit on the barbs.
Reply #31October 30, 2013, 11:10:14 am
« Reply #31 on: October 30, 2013, 11:10:14 am »
I've always used what I think is 1/8" diameter fuel line for the injectors and without problems. It's not clear. I get it at NAPA but you could try like a lawnmower shop too.
Reply #32October 30, 2013, 11:17:03 am
  • 2931
« Reply #32 on: October 30, 2013, 11:17:03 am »
 Right, there is a small but measureable amount of pressure.
 If it's blowing lines something is wrong.
 MK2s have a check valve in the return line, that can restrict flow.
Reply #33November 01, 2013, 09:22:52 am
92EcoDiesel Jetta
« Reply #33 on: November 01, 2013, 09:22:52 am »
A clogged tank vent can also restrict return fuel flow and increase pressure. The OE braided return hose fits onto the injector barbs much tighter than the Tygon polyurethane tubings and less prone to blowing off. Hoses are layered/reinforced, tubings are not.
Reply #34November 01, 2013, 03:51:51 pm
Mark(The Miser)UK
  • 1557
« Reply #34 on: November 01, 2013, 03:51:51 pm »
What happened to those micro clips that used to hold the braided leak-offs-on?
Tyler why are you keeping your manometer reading-pressure-proof  to yourself? ;D
Mark-The-Miser-UK
Reply #35November 01, 2013, 04:16:40 pm
« Reply #35 on: November 01, 2013, 04:16:40 pm »
Bashful...  ;)
Oh yeah! There was a wee bit of pressure in the returns, even with the gravity draw toward the tank.
More here:
http://www.vwdiesel.net/forum/index.php?topic=32794.msg305024#msg305024
Reply #36November 01, 2013, 07:37:41 pm
Mark(The Miser)UK
  • 1557
« Reply #36 on: November 01, 2013, 07:37:41 pm »
Was that veg colouring or blood?  On this forum it could easily be the latter ;D
Mark-The-Miser-UK
Reply #37November 01, 2013, 08:11:06 pm
« Reply #37 on: November 01, 2013, 08:11:06 pm »
Nah... this crowd is a basket of kittens.
(The electric vehicle guys are another story.)
Reply #38November 02, 2013, 08:36:27 am
« Reply #38 on: November 02, 2013, 08:36:27 am »
The c-210-a clear tygon hose is better than the stock braided hose in every way.  It lasts much longer, is more resilient, much less prone to leaks, clear for easy diagnosis, rated for biodiesel, etc, etc...  I've used it on more than 10 vehicles now for several years without issue.  Those vehicles include Mercedes and VW diesels (each generation from mk1 to ALH).  I have also used it for boost fittings without clamps where it has seen greater than 25 psi without any issues of leakage or popping off.
« Last Edit: November 02, 2013, 09:00:08 am by libbydiesel »
Reply #39November 02, 2013, 10:45:17 am
Mark(The Miser)UK
  • 1557
« Reply #39 on: November 02, 2013, 10:45:17 am »
Is there a 'best' tubing, for reuse purposes?
Periodic experimentation has me cutting the lines over-long to start with to get two or three reuses.
Clamps may have been the solution, but what the heck did I do with all mine ??? Only the one's on the boost remain...
Mark-The-Miser-UK
Reply #40November 04, 2013, 06:32:21 pm
Mark(The Miser)UK
  • 1557
« Reply #40 on: November 04, 2013, 06:32:21 pm »
OK, so I convinced myself that clips were a good thing for tubing reuse, so I bought 10 of these. Hopefully 6mm ones will crimp down sufficiently; or I'll be reforging them ;)
http://www.ebay.co.uk/itm/Mikalor-W1-SPRING-BAND-TYPE-Fuel-Hose-Clips-Silicone-Pipe-Clamp-Low-Pressure-Air-/260952027955?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item3cc1f3f333
Mark-The-Miser-UK
Reply #41November 04, 2013, 08:49:19 pm
« Reply #41 on: November 04, 2013, 08:49:19 pm »
Let us know how well they do the job.  I have gone to using very narrow zip ties.  I tried some thin braided copper wire but it cut through the rubber hoses and I wasn't any better off for it.
I love the differences in our languages.  dispatched in one day.  That would mean they would be dead not mailed to you.
So if you end up with a bunch of flattened pieces of metal you will know why.
Dispatched by Ball Peen.
Reply #42November 05, 2013, 03:50:06 am
Mark(The Miser)UK
  • 1557
« Reply #42 on: November 05, 2013, 03:50:06 am »
Mark-The-Miser-UK
Reply #43November 05, 2013, 11:40:41 am
mtrans
  • 308
« Reply #43 on: November 05, 2013, 11:40:41 am »
If you hate clips etc... like I do
like this 3 yr no problem,eazy conect-deconect
I`ll improve my English
Reply #44November 05, 2013, 05:25:03 pm
wolf_walker
  • 1205
« Reply #44 on: November 05, 2013, 05:25:03 pm »
There is a VW part number for the clips to hold those bypass lines on.  I have it, somewhere...
Never seemed to need any and have never seen them on a motor but they were in the EPC somewhere.
Never needed anything but the old braided hose either myself.  I don't run alternate fuels and generally leave
em alone once I install em.  They last as long as it takes an injector to need a nozzle or longer with fuel being what it is
these days in the US.  Every time I see someone have something that isn't the braided cover line on there it ranks
right up there with a fram oil filter.  Not that there aren't folks that have made informed decisions on an alternate line,
but it's the exception rather than the rule in my experience.
All that braided line isn't created equal either.
Mentat Text Two
