Help needed - mounting parts for the 1.6 TD injection pump
Topic: Help needed - mounting parts for the 1.6 TD injection pump (Read 2514 times)
August 06, 2012, 02:25:21 pm
TurboJ
August 06, 2012, 02:25:21 pm »
I need a picture that clearly shows how the injection pump is mounted on a 1.6D or 1.6TD.
It's been so long since my car was all in one piece, and recently I have only ever seen 1.9s (which have different pump mounts as you know).
I need the info to mount my pump correctly and also to see if my custom pump will fit the stock mounts (it's longer than a VW pump).
Any help is much appreciated!
Jetta II 1.6 TD 'Project 200'
August 06, 2012, 03:27:34 pm
knikula
Newbie
Re: Help needed - mounting parts for the 1.6 TD injection pump
August 06, 2012, 03:27:34 pm »
Hyvaa Pyvaa...
on a markII motor...
https://www.dropbox.com/s/q1xw8t8lb0wbfn9/IMG_0779.JPG
on a mark I motor, the passenger side mount is part of the same bracket...
not like this, but all in one piece...
https://www.dropbox.com/s/j7pvyrzlify3c3p/IMG_20120524_140329.jpg
hope this helps...
August 07, 2012, 10:49:00 am
TurboJ
August 07, 2012, 10:49:00 am »
Thanks!
Anyone have pictures of the mounting parts behind that wide plate?
August 07, 2012, 11:11:35 am
August 07, 2012, 11:11:35 am »
#14 it bolts to the block with two bolts, to the pump bracket/motor mount with two bolts and it is also the pumps back bracket support. The same for 1.5,1.6 and 1.9 IDI's.
August 08, 2012, 11:56:16 am
TurboJ
August 08, 2012, 11:56:16 am »
Is the pump actually attached to the engine block at all, or is it only bolted to the thick bracket on the pulley side of the engine?
August 08, 2012, 12:56:22 pm
August 08, 2012, 12:56:22 pm »
Can you see my picture? Can you read what I wrote?
The small bracket that is highlighted, #14. It attaches to the back of the pump, #24.
#14 then attaches to the block with two of #15. Two more of #15 attach bracket #14 to the pump bracket on the pulley side. of the pump, which is also the mk1 motor mount.
August 09, 2012, 03:46:41 pm
TurboJ
August 09, 2012, 03:46:41 pm »
Hey, thank you so much!
I was in such a hurry last time round that I didn't even notice what you had written on top of the picture....
This should make it easier for me, even though I remember that my car did have a somewhat different mounting system.
In any case - that you!
