General Information
Troubleshooting
How to clock turbo exhaust side
Topic: How to clock turbo exhaust side (Read 4741 times)
February 16, 2006, 09:54:31 am
myke_w
February 16, 2006, 09:54:31 am »
I am at a loss for how one goes about clocking the exhast side of the turbo to the center cartridge. Mine is such a tight fit, that I have to heat the hot side to get it to even fit down in... Of course, once its fit in, it's tight, and the bolts cant be started because there's no clearence. I've cleaned it well too, can someone help? I need to get this clam back together..
February 16, 2006, 07:13:09 pm
myke_w
February 16, 2006, 07:13:09 pm »
I am really surprised someone hasn't done this... Any insight at all? :roll:
February 16, 2006, 08:38:35 pm
fspGTD
February 16, 2006, 08:38:35 pm »
I really doubt those pieces are supposed to be an interference fit like you describe, but I have found they can get bound up due to rust and scale build-up on the mating surfaces.
Try wire brushing the rust off the outer edge of the center section (using a bench wire wheel or a stiff hand brush) as well as inside the groove of the turbine housing (using a stiff hand brush or rotary die-grinder brush.) Go at the rust until it is just smooth bare metal.
I'll bet that with the rust removed, that the pieces go together nice and tight, but not bound up. Hope this helps... good luck.
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
February 16, 2006, 09:42:44 pm
Justin
February 16, 2006, 09:42:44 pm »
the IHI turbo that I run had a small little metal dowel pin in it to keep the exhaust part from rotating, try that
good luck, this isnt the mike that I bought a 1.5 off of ebay is it???
later
Justin
www.archeryprostaffmi.com
February 18, 2006, 07:56:09 pm
myke_w
February 18, 2006, 07:56:09 pm »
Ok, so I assume I don't need heat at all?
That would make sense as to why the bolt clearence is screwing me..
February 18, 2006, 07:57:05 pm
myke_w
February 18, 2006, 07:57:05 pm »
I have not sold any 1.5's on ebay. where was your guy from?
February 19, 2006, 09:56:20 pm
Justin
February 19, 2006, 09:56:20 pm »
I forget where but i saw that it was a new guy from ohio that had stuff for sale and that guy was always wheeling and dealing
good to have you
later
Justin
General Information
Troubleshooting
