Author Topic: Stupid horn ground question - A1  (Read 4291 times)
July 06, 2012, 08:50:01 pm
wolf_walker
  • 1205
« on: July 06, 2012, 08:50:01 pm »
This is the second caddy I've seen that has a ground via the steering column tube, but NOT the center shaft.
Should this thing ground through the rack somehow or was it just a "ahh, it'll ground somewhere in there"
kinda setup?  This has to be in the top ten stupid car problems I've ever seen.
Mentat Text Two
Reply #1July 06, 2012, 10:13:11 pm
Re: Stupid horn ground question - A1
« Reply #1 on: July 06, 2012, 10:13:11 pm »
by the drivers sid rack mount... there is a wire from ear on rack to body....
old ones has a steel bushing to do this in the column... newer ones got a rubber/plastic bushung... and that makes it require a wire...
Reply #2July 09, 2012, 09:06:55 am
wolf_walker
  • 1205
« Reply #2 on: July 09, 2012, 09:06:55 am »
Found it, never noticed that damn screw, and there was a terminal on it with the wire ripped off.  Hopefully this fixes this part of the problem.
Thanks...
Mentat Text Two
Reply #3July 12, 2012, 01:05:45 pm
rabbitman
  • 2788
« Reply #3 on: July 12, 2012, 01:05:45 pm »
Horn didn't work on my rabbit until I found that wire and gave it a tap, must have wiggled enough 'cause it's worked fine for 5 years now.
Reply #4July 12, 2012, 01:14:04 pm
wolf_walker
  • 1205
« Reply #4 on: July 12, 2012, 01:14:04 pm »
I don't think I've ever actually put a rack in one of these or I'd have seen it.  I was glad to make it's acquaintance.
Mentat Text Two
