Author Topic: Alternator not charging, and no battery light.  (Read 4333 times)
July 03, 2012, 02:19:50 pm
Tom77
  • 16
« on: July 03, 2012, 02:19:50 pm »
The car is a 82 Rabbit Diesel, the alternator is good, was tested, the battery light on the dash doesn't come on, even when the key is on, only the oil light.
I replaced the dash, but same thing, no light, and no charge.
Any suggestion?
Thanks.
Reply #1July 03, 2012, 03:29:23 pm
Re: Alternator not charging, and no battery light.
« Reply #1 on: July 03, 2012, 03:29:23 pm »
the only time the light doesnt come on (from my experiences) is because the exciter wire is un-hooked from the alt, or if the light is burnt out..
have you confirmed with a volt meter that there is no charge coming from the alt?
Reply #2July 04, 2012, 05:17:28 am
Tom77
  • 16
« Reply #2 on: July 04, 2012, 05:17:28 am »
Yes I did, also the alt was tested at two different locations, and passed.
I don't think is the light, because I replaced the dash, with a spare.
Probably is what you said, the wire is un-hooked somewhere.
I did a continuity test from the rubber plug that goes to the alt, to the plug in the dash, the only one that failed was the blue wire.
Can I bypass the blue wire?
If so, what I have to do?
Thanks
Reply #3July 04, 2012, 12:03:01 pm
« Reply #3 on: July 04, 2012, 12:03:01 pm »
Thanks
that blue wire is what operates the light. if the blue doesnt work, the light doesnt work..
