Author Topic: Metal injection lines breaking (2x) 1.6na  (Read 3328 times)
June 21, 2012, 10:10:34 pm
purvisgs
  • 45
« on: June 21, 2012, 10:10:34 pm »
One of the metal injection lines (#2 cyl) cracked right by the injector nut a couple of wees ago, and I assumed previous owner may have not tightened correctly , or just old metal line, bad motor mounts etc.
I replaced with a used one and made sure the line clamps were on correctly and tightened the lines down correctly.  I just had the replacement line break in the same spot -after about 50 miles driving it.
Any advice?  Injector is not obviously "loose" or anything, threads look fine, and I know it vibrates a little more than average (could use motor mounts). but ?
Anything I might be missing, even the obvious..would be greatly appreciated.
Thanks!
Reply #1June 21, 2012, 10:58:01 pm
Re: Metal injection lines breaking (2x) 1.6na
« Reply #1 on: June 21, 2012, 10:58:01 pm »
You need the dampers that clip the lines together.
You must loosen the lines before  rotating the pump to relieve torsional stress.
If a ham fisted gorilla sits on them, they may crack later.
That's all I got.
Reply #2June 22, 2012, 12:52:47 am
« Reply #2 on: June 22, 2012, 12:52:47 am »
the admin of the kubvan fourms has just broken 3 in the past few mo.. il tell you what i told him...
loose pump, motor mount bracket bolts need checked too..
no clamps between the lines
no one loosened/retightened the lines after a pump adjustment..
those are the 3 things i know of... a injector sticking.. i highly doubt it...
Reply #3June 24, 2012, 07:03:16 pm
