Author Topic: Injection pump questions  (Read 2657 times)
June 18, 2012, 07:54:13 pm
firestorm13666
  • 204
« on: June 18, 2012, 07:54:13 pm »
I have a 86 golf with a 1.6 with cold start adv on the pump, and I picked up some 1.5 parts cheap while back. Now I'm wondering if i could use the 1.5 pump in place of my leaking one. The pump looks to be in better shape then the one I'm running now. I took some pics of the pump's numbers,so any advice would help. Thanks
Reply #1June 18, 2012, 07:58:08 pm
Blocksmith
  • 261
    Wrench Lurker
Re: Injection pump questions
« Reply #1 on: June 18, 2012, 07:58:08 pm »
Yes, you can switch them, no problem. I'm running a 1.5 pump on my 1.6 right now. Works fine.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #2June 19, 2012, 05:57:40 am
« Reply #2 on: June 19, 2012, 05:57:40 am »
It will work. You'll even gain 200 RPM before the fueling cuts out
Reply #3June 19, 2012, 01:24:25 pm
« Reply #3 on: June 19, 2012, 01:24:25 pm »
didnt the 1.5 pump dump more advance in sooner as well?
Reply #4June 19, 2012, 03:48:56 pm
« Reply #4 on: June 19, 2012, 03:48:56 pm »
I can't remember, I rarely saw the bosch sheets for the 1.5s :(
Reply #5June 19, 2012, 04:04:30 pm
  • 4553
« Reply #5 on: June 19, 2012, 04:04:30 pm »
Didn't you have to pull the shims out from between the spring and the piston to get the advance to come on early?  Can't that be done on all IPs?  1.5 pumps might have had the stiffer springs and more shims.  I can't remember all the details with out a look up on it.
Reply #6June 19, 2012, 06:40:30 pm
firestorm13666
  • 204
« Reply #6 on: June 19, 2012, 06:40:30 pm »
Thanks for the info. I picked up a 1.5 of unknown year and was hopeing to use some parts off of it for my 1.6. The engine looks clean up had the head off for while so there is rust on the walls, but it turns over by hand.
Reply #7June 20, 2012, 09:31:52 am
« Reply #7 on: June 20, 2012, 09:31:52 am »
well, if its a 1.5, then its from between 76-80... those are the only years they were produced..
