G60 valve cover
Topic: G60 valve cover (Read 3377 times)
May 20, 2012, 07:37:19 am
92EcoDiesel Jetta
G60 valve cover
May 20, 2012, 07:37:19 am »
Will a G60 valve cover fit my diesel head? What are they worth?
May 20, 2012, 08:27:31 am
Re: G60 valve cover
May 20, 2012, 08:27:31 am »
0.3242346 seconds on google..
Use the tools given to you my friend! LOL
May 20, 2012, 10:29:49 am
Moderator
4553
Re: G60 valve cover
May 20, 2012, 10:29:49 am »
Better that he asked here. Look at that nice picture he got. And what year is that intake on the airbox? Mine is oval up front and I would like a round one like that to put a hose on. Trying to get a round hose to clamp on the oval is not working for me.
May 20, 2012, 10:35:41 am
Re: G60 valve cover
May 20, 2012, 10:35:41 am »
I do believe it is an early one.. 1.5 maybe?
May 20, 2012, 10:49:00 am
Wayland
Re: G60 valve cover
May 20, 2012, 10:49:00 am »
Yes, that's a 1.5 airbox. I like the grey plastic plumbing fitting on the breather line!
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
May 20, 2012, 11:46:18 am
92EcoDiesel Jetta
Re: G60 valve cover
May 20, 2012, 11:46:18 am »
I would if I could. I was at a VW show and saw this G60 valve cover and tried to do a search from my phone but the signal was fading in ad out, I was barely able to send my post.
Anyway took a chance and bought the G60 VC/ windage tray for $20, both manuals in pristine condition for $12, all mouldings for $5. What's cool is the long moulding is the one I been looking for to replace the one some a**hole stole from my car in a municiple parking lot 6 months ago. I think I did ok?
Quote from: 8v-of-fury on May 20, 2012, 08:27:31 am
May 20, 2012, 04:46:11 pm
Blocksmith
Wrench Lurker
Re: G60 valve cover
May 20, 2012, 04:46:11 pm »
$20?? HELL YES, you did well. Good snag there.
Last Edit: May 21, 2012, 06:05:20 am by Blocksmith
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
May 21, 2012, 02:28:33 am
damac
Re: G60 valve cover
May 21, 2012, 02:28:33 am »
You got a good deal, I think I paid over $60 for mine with the breather.
In my case I got it because I thought the oil leaks were from a bent stock piece, didn't care for the looks.
I found out my engine had major blowby and pressures and it resulted in oil getting push passed the rubber kit constantly. Got a different healthy engine now that doesn't smoke like a train out the oil fill and I don't see a drop yet
1985 turbo diesel jetta
May 21, 2012, 04:55:17 am
92EcoDiesel Jetta
Re: G60 valve cover
May 21, 2012, 04:55:17 am »
Primarily I want it for better seal, secondary looks. the one on the car currently is all rusty and bent. I have straightened it best I could but it still leaks a little.
did yours fit without modification?
May 22, 2012, 09:59:31 am
damac
Re: G60 valve cover
May 22, 2012, 09:59:31 am »
I have a stock setup 85 jetta td. I installed the single rubber valve cover gasket kit, you have to take out the old studs and install the ones that come with the full kit.
It fit just fine, just like the other you tilt a bit to get started and then even it out and drop it in, I did not have to take a dremel to it or anything.
It could work for you in that regard, maybe yours is too bent out of shape.
Also when I did mine I have a vane type vacuum pump and the block plate was blocked off so I took the time to get a single nippled plate and added another hose from it and t'd it into the valve cover/intake plumbing. Mine has a square breather that screws into the cover and the nipple came out the opposite direction.
G60 valve cover
